Heated Seat Problem...
Old Dec 3, 2009 | 12:59 PM
kwikslvr's Avatar
Rotary User
So i did a search and could not find any thread pertaining to my exact issue, so i am started a new thread.
I have an 04 GT with heated seats, well 1 heated seat, that's the problem. My passenger seat does actually get warm when the heaters are turned on, but my driver seat does not. With winter coming it would be nice to have my Butt Warmer up and running.
i would check the Fuse, but im assuming they would both be hooked to one.
Any Ideas?
Thanks ahead of time.
Old Dec 3, 2009 | 01:03 PM
dozer's Avatar
on his 3rd rx8
check the connection to the buttons
Old Dec 3, 2009 | 01:05 PM
mscamp02's Avatar
Blue Bullet?
Mine has had the same problem but I really dont use them so I havent bothered to check anything on it
Old Dec 3, 2009 | 01:06 PM
kwikslvr's Avatar
Rotary User
The lights on both buttons come on, so it appears that everything is good there. i guess it may be the heater itself or the wires from the switch to the heater. if it is the heater, is that replaceable or not?
Old Dec 3, 2009 | 01:11 PM
mscamp02's Avatar
Blue Bullet?
hmmm...you could try just switching the connectors around to determine if it is the seat or if it is the connectors. Because if the drivers seat gets warm with them switched then you know where the problem is....same thing in reverse.
Old Dec 3, 2009 | 01:12 PM
DubbsLuvs8s's Avatar
Mine does the same butt (hehehe) opposite. My seat gets warm, but the passenger doesn't seem to.
Dealership told me it was fine, I think they lied.
In all honesty, the passenger seat does do something, but it's not nearly as effective as my seat.
Old Dec 3, 2009 | 01:38 PM
The Reverend's Avatar
That's a lie
The connectors are different colors, I am not sure they can be switched
Try looking under the seat as well.
Old Dec 3, 2009 | 04:15 PM
mscamp02's Avatar
Blue Bullet?
yea ones black and ones tan but i think they were the same, cant remember cuz its been a while since ive been under there
Old Dec 4, 2009 | 09:21 AM
kwikslvr's Avatar
Rotary User
yeah i didnt get a chance to look last night (was helping a friend put a new axle in his integra) but i'll look at it over the weekend.
Thanks for all the input.
Old Dec 4, 2009 | 10:17 AM
mscamp02's Avatar
Blue Bullet?
put up a post if you get your seats working cuz apparently there are a lot of people with this issue
Old Dec 4, 2009 | 11:01 AM
bmak's Avatar
My seats are both working fine. IIRC, there is a difference in the seat design, one of the seats has heating elements in the bottom of the seat and in the lower back area of the seat, the other has only the bottom portion, not the lower back. If you're thinking that one doesn't work, make sure that this isn't what you are experiencing.
Old Dec 10, 2009 | 07:19 PM
merkidemis's Avatar
I am currently having this issue as well. My driver's side seat doesn't work, even though the light on the switch comes on. I'll try the swap thing tomorrow or Saturday, as it is really numbingly cold outside right now.
Old Dec 26, 2009 | 06:18 PM
elysium19's Avatar
any insights? having the same problems.
and there are TWO "seat warm" fuses in the fuse box!! one big, one small, anyone know the difference???
Old Dec 29, 2009 | 08:38 AM
robbz23's Avatar
I have the same issue here and let me tell u it is freaking cold here in sweden. So i pulled up the diagram and i checked everything from the switches to the connector under the seat. When I disconnected the connector and checked the resistance on the circuit for the heater it appears that there is a short some where in the seat. I tried the same on the passenger side that was working but had a hard time seeing and it got really cold so I came back inside. Oh and yes mine is a normal US car imported to sweden.
Old Dec 31, 2009 | 08:26 PM
greenarixate77's Avatar
I have the same problem as well. The driver's side switch seemed to light up when turned on; but no heat comes up.
I disconected both driver's and passenger's heat warmer switch - they cannot be switched around to tell if one of them is not working because the end fitting for both assemblies are different.
My fuse seemed to be fine. I'm not sure what the issue would be.
Old Jan 5, 2010 | 01:49 PM
otakurx's Avatar
Rotorheaded Geek
I have developed this same issue. I've assumed it is the wiring in the seat itself since it seems to have coincided with the airbag warning light coming on. I have found wiggling the wires makes everything work again at least for a little while. I plan on digging into it this coming weekend as well as my power steering wiring.
Old Jan 5, 2010 | 01:53 PM
robbz23's Avatar
Looks like I found the solution for mine today, a wire inside the seat cover had been completely clipped. I will post some pics and troubleshooting techniques later.
@otakurx -- Yours definitely sounds like the main connector under the seat is loose some how. If the airbag warning light is going off. I had the same issue on my passenger side and it went away when i reseated the connector
Old Jan 6, 2010 | 10:01 PM
robbz23, did you have to take the seat out of the car to find this out? Was the connector attached to the bottom cushion?
Old Jan 7, 2010 | 12:19 AM
robbz23's Avatar
Yes -- I took the seat out and removed the cushion. The line going up to bottom seat cushion was broken. I have some pics that will help and I will try to post them today.
Old Jan 7, 2010 | 01:42 AM
robbz23's Avatar
Hey guys I wrote it up as a DIY with pics from my fix and shots from the repair manual that should help.
https://www.rx8club.com/showthread.php?p=3378725
Old Jan 9, 2010 | 04:58 PM
Thank you so much, Rob. You the man!
Old Jan 12, 2010 | 11:14 PM
TBAGG's Avatar
Hey - just so you know I had the 'Power Steering' light come on and the power steering not working. But it was intermittent. I took the car to dealer and he was like "yeah... we cleaned the connector... it works now... no big deal" ... so if you are still having this issue just remember to 'Clean Your Connector' instead of 'Wiggle Wires'
Old Aug 30, 2013 | 08:59 PM
vukovi's Avatar
link broken
Hi, I have an issue with my seats, and I am pretty sure they were clipped by the previous owner for some strange reason. However, the link above does not work. It just loads a blank page. Could someone check on that?? Or just repost the pics here?
Old Aug 30, 2013 | 09:00 PM
vukovi's Avatar
ummm ok it works... maybe I had to be signed in?
alming1132
Sep 30, 2015 11:30 AM
XianUnix
Sep 29, 2015 03:48 PM
DeltaJ802
Sep 29, 2015 01:20 PM
