Installing second oil cooler
Old Nov 24, 2009 | 06:04 PM
irx08t's Avatar
AU Installing second oil cooler
Hi,i need some help installing the driver's side (in Australia) 2nd oil cooler.I'm trying to do this at the moment.
For those that have done it, did you have to remove the battery and airbox to bolt up the lines that connect the two coolers? I'm having trouble from underneath finding where the brackets go? I bought all the stuff second hand so i don't have any instructions.
I'm also a little confused as to which hoses connect up where,i.e from new lines to which cooler lines etc?
I also need the little clips that hold the quick release joints in place,Mazda only sell as the whole joint at a ridiculous price! Does any one have any spare or know where i can get some? See attached picture.
Any help greatly appreciated.
File Type: pdf
Old Nov 24, 2009 | 06:14 PM
Brettus's Avatar
Boosted Kiwi
I have fitted the extra cooler - not as an oil cooler but as an extra water radiator .
It worked a treat .
Can't help with pipework (cuz i ended up not useing it ) but I do know someone who will have that clip (I gave him all my pipes and he never used them . Let me know if you get stuck and you can have it for the cost of freight from NZ .
ouimetnick
25
Sep 14, 2023 01:44 PM
foxyRoXy8
Aug 18, 2015 10:26 PM
RXeckless
Aug 16, 2015 12:52 PM
RXeckless
Aug 16, 2015 12:51 PM
