Low Temp Thermostat?
Old Nov 13, 2009 | 07:14 AM
rx8dorifto's Avatar
Is there any low (lower) temp thermostat available for RX8?
I know Mazmart has one that opens at 76deg C but it might not be low enough for my climate here in Far East Asia. I've bought it but haven't install it coz something troubled me. There are so many aftermarket thermostat for other performance car which opens at 68deg C. But just couldn't find any 68dec C thermostat for RX8.
There is 68deg C thermostat for RX7 and Miata, are they compatible for RX8?
Old Nov 13, 2009 | 09:03 AM
longpath's Avatar
I'm also curious if previous thermostats for the 13B will work in the Renesis.
Old Nov 13, 2009 | 12:36 PM
no
Mainly because if the temperature is too low, it will might affect Fuel trim = CEL.
Rx-7/Mia works because - Rx-7 is older, not as strict emission
Miata - Different engine has different optimal operating temperature.
Mind you, a Thermostat will NOT fix any overheating problems.
if your car is already overheating, well, you need better radiator/coolant vs water ratio/Fan/mods/etc
Old Nov 13, 2009 | 04:44 PM
Pico's Avatar
It's Complicated
^ Yep
The longer it take for the car to reach the correct operating temp. the harder the car works. Thus, your car uses more fuel while trying to achieve the correct temp.
I know in a lot of car (not sure bout the 8) the PCM will not communicate with the MAF, IAT until the car has reach the correct operating temps. Anyone know it the 8 works in the same fashion?
Old Nov 13, 2009 | 07:02 PM
longpath's Avatar
Are the 13B thermostats physically compatible? I'm asking particularly with regard to the possibility of Summer and Winter thermostats (I remember that one of the RX-7s had an option of a higher temperature thermostat as well, presumably for winter/cold weather use) or thermostat options for those who live in more extreme climates.
Old Nov 13, 2009 | 07:59 PM
I do not think so.
Old Nov 14, 2009 | 09:31 AM
arghx7's Avatar
Mazda has used the same thermostat opening temperatures since at least the Rx-2 (12A engine):
Attached Thumbnails Low Temp Thermostat?-thermostat_rx8.jpg   Low Temp Thermostat?-thermostat_rx2.jpg
Old Nov 14, 2009 | 03:17 PM
go with the Mazmart unit.
as has been mentioned, you don't actually want the temperatures to be TOO low.
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Michael Bryant
Oct 12, 2015 03:07 PM
MolecularConcept
11
Sep 29, 2015 09:21 PM
xAgyex
Sep 28, 2015 08:54 AM
