Coolant leak
Old Nov 9, 2009 | 07:17 AM
gusmahler's Avatar
AZ Coolant leak
I have a coolant leak somewhere in my 2004 RX8. I don't really have the money to get it looked at by a professional, at least not for a few weeks. Any opinions on Bar's Leaks or other types of stop leak products? Are they safe to use on a rotary engine?
Old Nov 9, 2009 | 09:38 AM
tmak26b's Avatar
No, just do old fashion investigative work to see where the leak is coming from. Put a light down to see if you can trace it, most likely the hoses or the waterpump
Old Nov 9, 2009 | 06:52 PM
I wouldn't use the leak crap on anything except a beater that you never plan on keeping
Like Tmak said...most likely are hoses or water pump. If your hoses are 5yrs old they may be getting kinda long in the tooth.....
Old Nov 9, 2009 | 08:24 PM
Old Rotor's Avatar
As dannobre said ++. Just show us some pics of where and when. Give us some info on your car. It might be something simple. We might be able to give you some direction....
Old Nov 13, 2009 | 06:48 PM
gusmahler's Avatar
The leak is coming from the radiator. It doesn't appear that the bottom of the radiator is leaking at all. So I'd guess that there's a leak somewhere that drips down the radiator. The drip comes from the corner of the car (on the driver's side).
Old Nov 14, 2009 | 03:38 PM
Upper tank Leak??
Old Nov 14, 2009 | 06:53 PM
04RX8man's Avatar
Rotary Powered Countryboy
^yes.....possibly.....check the radiator over...and make sure that you didn't just have coolant come out the overflow hose on the tank and get on the rad.....but dry off the rad and make sure it's not leaking...
Azki23
Jun 27, 2018 03:48 PM
DG07
Sep 28, 2015 10:58 AM
drlubell
Sep 26, 2015 11:58 PM
Rx8_412
Sep 24, 2015 08:51 PM
Draken
Sep 21, 2015 06:14 PM
