Tire Sensor
Old Nov 5, 2009 | 09:28 PM
Spectre5's Avatar
Tire Sensor
I'm considering a set of winter tires for this upcoming winter. I have a couple of questions. Do I need to get the sensor on the tires (I've seen it usually run ~$50/tire...). What would happen if I don't have the sensor on the tire? Would the low pressure light stay on or off or what?
Also, do I NEED to get a set of 4 tires? Since the car is rear wheel drive, is it OK to just get 2 rear snow tires? It does have the 4 wheel braking though...
Thanks for the input!
Scott
Old Nov 5, 2009 | 09:49 PM
Cam's Avatar
Cam
this space for rent
yes, the TPMS light will stay on.
You could run only 2 winter tires, make sure all 4 are the same size though. Better to run 4 winter though
JimmyBlack
273
Feb 10, 2020 10:23 PM
CMRine04
Sep 17, 2015 10:04 AM
yankeepicker
Sep 11, 2015 05:42 PM
fireishot34
Sep 5, 2015 06:45 PM
20b-3rotor
Sep 2, 2015 08:54 AM
