Tein S-Tech Install Help!
Old Nov 5, 2009 | 06:36 PM
Mun1688's Avatar
Hey guys, I am in the middle of installing my springs. I already got the rear ones installed. I am now on the driver side front.
I am following these instructions....
https://www.rx8club.com/showthread.php?t=23403.html
I already removed the strut bar and the other 3, 14mm screws that were at the top under the hood. I have also removed the 17mm bolt at the bottom. But for some reason the strut is still in there really good and it wont budge.
The instructions say remove the two upper 14mm control arm bolts..... But I dont see them??
Help plz.
Old Nov 5, 2009 | 06:40 PM
HockeyRX-8's Avatar
TNC
they are connected to the top a-arm
Old Nov 5, 2009 | 06:43 PM
Mun1688's Avatar
Those are 17mm bolts... right?
Old Nov 5, 2009 | 06:47 PM
HockeyRX-8's Avatar
TNC
they should be
edit: actually i keep forgetting if they are 14 or 17 mm...it's one or the other
Old Nov 5, 2009 | 09:15 PM
thejew89's Avatar
another broken syncro
they are 17mm
Old Nov 5, 2009 | 09:55 PM
If you cannot get the fronts out you should stop now. Sounds to me like you are in over your head. Good luck with the rears.
Old Nov 5, 2009 | 10:18 PM
8 Maniac's Avatar
Senior Member
Said he already did the rears if I'm reading correctly. Either way, good luck, hope it works out for you. It sounds like you had your questions answered
Old Nov 5, 2009 | 10:20 PM
Ah, my bad. Missed that. Seriously though the rears are a lot harder, the fronts are simple.
Old Nov 6, 2009 | 09:20 PM
Mun1688's Avatar
Yea I heard that the rear ones were harder. Anyways I got the drivers front side one on.
Im on the passanger side one at the moment. Now the problem that I am having is that the main nut that hold the whole strut together wont screw in all the way in. Its like I eat the threads up or something which I know I didn't. I had the same problem with one of the rear ones so all I did is tell my friend to push down on the struts so that I could get under the nut with a small wrench. Then all I did is put pressure upwards on the wrench and with the 17mm socket I unscrew it from the strut.
(THE NUT I AM TALKING ABOUT IS THE ONE AT THE TOP OF THE STRUT THAT HOLDS EVERYTHING TOGETHER) (17MM NUT)
But for the front one, that wont work.... This is getting really frustrating. The nut wont screw in or out.... Should I put it on the car without it being screwed in all the way???
Thanks for the help on the driver side ones guys.
Old Nov 6, 2009 | 09:48 PM
Mun1688's Avatar
Here is a pic for some that don't understand...
This one if correct:
http://i95.photobucket.com/albums/l1...8/IMAG0012.jpg
This is the one that won't screw in all the way:
http://i95.photobucket.com/albums/l1...8/IMAG0013.jpg
Old Nov 6, 2009 | 10:43 PM
Juice's Avatar
I made some poos
Will it not screw on, or is the shaft turning preventing it from screwing on?
Try and put an allen wrench on the top to hold the shaft still and turn the nut with a regular box wrench.
Old Nov 6, 2009 | 10:52 PM
Mun1688's Avatar
Its already on, but I cannot screw it in anymore. Its not stuck or anything, I can try to tighten it all I want, but it just keeps going and going but stays in the same place. Its endless lol.
Old Nov 7, 2009 | 03:31 AM
Mun1688's Avatar
Ohhh I know just got what you were saying.
Thanks A LOT that did the trick. Im a dumass for not noticing it lol. THANKS MAN!
EDIT: I'm done with the install, thanks for all the help guy. I will post some pics tomm after I was the car over at RX-8 Multimedia/Photo Gallery. Look for it!
AGAIN THANKS GUYS!
Old Nov 7, 2009 | 04:01 AM
Juice's Avatar
I made some poos
Sorry I got back to this so late, forgot about the thread after I got home from work. Glad you got it all installed though. I figured once you realized what was happening my post would make sense.
Old Nov 11, 2009 | 02:21 PM
DavidR's Avatar
I hope it looks great and is leveled, I installed mine last year in December and the right side of my car is still higher than the left side
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Zube6115
Sep 30, 2015 12:57 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
