slverrx8
11-01-2009, 10:24 PM
hey guys. my motor overheated and im replacing it with a motor from a 8 that was rearended with 15k miles on it. i was sold just the block, and i was wondering if you guys would be able to tell me what parts i need and what parts i would be able to salvage of the old motor. thanks in advanced.
dannobre
11-01-2009, 11:11 PM
You should be OK with the old parts off your long block......
Carefully remove the bits/ clean and lube, and transplant to the new block and you should be good to go. You should get new injector o-rings and grommets and might need a few gaskets and seals...depends what kind of shape your old ones are..IE the intake rubber seals
You might want to have the injectors cleaned...and replace the thermostat just to be sure..
Why did it overheat??
slverrx8
11-02-2009, 07:20 PM
a leak in the radiator/broken goose neck on reseviour tank+103 weather+stop and go traffic+=fail.
88dblifestyle
11-04-2009, 01:55 AM
Maybe this site can help you with your problem, hehe take a look at here 88DB Singapore Automotive (http://sg.88db.com/sg/Services/Ad.listing/Automotive/Spare_Accessories/?O=post&Q=&CatID=3010000&SubCatID=3011100&Image=1&Page=1).
Hope it helps!:aroused:
