Vacuum Hose diagram? and Airpump info
Old Oct 27, 2009 | 08:43 PM
eyecandy's Avatar
Is there a vacuum hose diagram out there for the RX8? Or a downloadable FSM? I am looking for connections for the airpump, air control valve, plus and wiring for those. I am trying to swap the RX8 air pump into my FD3S, I know most people just wire a switch on/off, but I want to try to do it right. I believe the RX8 air pump is only on for about a minute then shuts off, I forget where I read that, its been awhile maybe 2 years... So I figure if I can wire it up similar to the RX8, plus me using a metal cat which lights off faster (gets up to operating temps quicker) I should be set.
One last thing is the a service highlights book for the RX8? There is one for the FD3S, and its a great read explains how everything works!
Thanks for the help!
Old Oct 27, 2009 | 08:51 PM
Jon316G's Avatar
Grasshopper
https://www.rx8club.com/showthread.p...ervice+manuals
Old Oct 27, 2009 | 10:18 PM
Spoolin8's Avatar
isnt the airpump just for emissions? You dont really need one do you?
Old Oct 27, 2009 | 10:41 PM
eyecandy's Avatar
LOL I would not be inquiring if I did not need one...
Is that really the FSM?? Its totally different then any other FSM I have seen, where is the TOC? Does any one have the vac diagram and emissions/fuel/engine wiring diagram?
Old Oct 27, 2009 | 10:50 PM
Jon316G's Avatar
Grasshopper
Yes
where is the TOC?
Each PDF is its own section
Yeah... look in the appropriate PDF.
Wiring diagrams can be found in the 'Electrical' PDF.
theblinkof
Oct 4, 2023 05:24 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
Evan Gray
Nov 24, 2015 01:00 AM
garryg
Australia/New Zealand Forum
Oct 1, 2015 04:54 PM
