View Full Version : Oil Change Help
tamz273
10-21-2009, 02:44 PM
Hey Guys,
I was planning on doing an oil change this weekend. Im currently using 5w20, as recommended by the dealership, but I wanna make the switch to 10w40. I live in Boston, where it gets pretty cold in the winter. (10-20 F) My mileage is just above 66k, and my last oil change was at 52k. Do you guys think I should make the jump to 10w40? Or do something less/more dense? Also, how will my car's performance change with the denser oil, if it will change at all?
chino0314
10-21-2009, 03:19 PM
i run 10w30....
but then again im in miami...
also why was you last oil change so long ago?
tamz273
10-21-2009, 03:34 PM
Its been a while because I didnt pay attention to the sticker on the service. I dont drive my car hard really. Its a day to day car, and I just top off oil as I go. Now that Im reading around though, it seems as though I should really put more thought into the oil I use because it can be the make/break of my engine..
dannobre
10-21-2009, 10:07 PM
5-30, or 5-40 would be a much better choice.....
tamz273
10-22-2009, 09:50 AM
How does the climate play a roll in the oil I pick? Im just getting into the winter here, and I dont know if the wrong oil may cause problems? Right now I have these oils listed:
Rear Differential - Redline 75W90
Tranny - Redline MT90
Engine Oil - 5W30 (Brand??)
Huey52
10-22-2009, 10:07 AM
5w-30 recommended in our area for Winter (I actually run it year round).
The "5w" refers to 5 degF Winter low end temp viscosity. I know that it rarely gets below 10 degF here, but 5w has become the defacto standard.
The -30 is the Summer viscosity rating (not a temperature range per se, but related) and recommended over the "dealer recommended" -20 as rotaries tend to need a higher vscosity.
edit: your tranny and differential selections are right on.
I like Castrol GTX for my motor oil, but there are a number of good brands.
ken-x8
10-22-2009, 03:31 PM
Here's something that should help. I don't remember who first put it up, but I've reposted it several times. Shows engineering, rather than political, oil grades.
Ken
tamz273
10-23-2009, 09:56 AM
Awesome! Thanks guys for the help! I really appreciate it! My other question is how much oil does each of those take? Diff/tranny/engine? Since Im gonna be ordering online, I need to know how much to order...
Huey52
10-24-2009, 11:39 AM
You need to order 2 qts of each for the tranny and differential. The Oil change, with filter, is ~4 quarts.
All the capacities are in your owner's manual.
rx 8speciale
10-24-2009, 11:51 AM
i run 10w30 year around
tamz273
10-26-2009, 09:55 AM
Awesome! Thanks for the help guys.. Really. And I guess I'll make the move to Castrol. I use Mobil1 right now, but since more people use Castrol than other stuff here, I'll go with it! Another question since I'm buying everything online. Any recommendations for sites with Filters and Spark plugs? Anything else I should get replaced while Im at it?
Huey52
10-26-2009, 10:13 AM
Summit Racing for the Redline oils and FinishlinePerformance.com for the filters and 'plugs (Rosenthal Mazda - excellent vendor here). Black Halo Racing (BHR) here has good deals on plugs as well, and sparkplugs.com.
Perhaps new coils?
tamz273
10-26-2009, 10:37 AM
Also, any comments on this?
http://www.amazon.com/Royal-Purple-Synthetic-Extreme-Performance/dp/B000BRTJP4/ref=sr_1_1?ie=UTF8&m=A1T0VEFK4F7RX4&s=automotive&qid=1256567794&sr=1-1
tamz273
10-26-2009, 10:38 AM
And where can I get coils? Also, are they easily replaceable at home?
Huey52
10-26-2009, 10:42 AM
Finishline also has the coils and yes they are easy to install with minimal tools/experience. See the DIY.
Some people like Royal Purple motor oil (would not recommend their trans/diff'l oil in the '8)., but everyone likes Castrol GTX. ;) Just grab a gallon jug at Autozone.
tamz273
10-26-2009, 10:45 AM
Awesome, ill do that! Im looking on finish Line, awesome website! Glad you pointed me to them! Im gonna order some plugs, my Redline oils, filter, and some coils from there! My question here is which crush washer should I get? And how many coils?
EDIT:
I figured out the washers, now its just the coils. How many do I need?
Huey52
10-26-2009, 12:06 PM
Get your 'plugs easily from BHR's new site: http://blackhaloracing.com/products-page/engine/ignition/ngk-iridium-spark-plugs-oem-heat-ranges3/
The proper oil pan crush washer comes with the oil filter from Finishline - one of the reasons they're recommended.
You need four (4) coils. Again, check the DIY.
If you Really want a solid ignition upgrade to BHR's system. http://blackhaloracing.com/products-page/engine/ignition/bhr-ignition-system6/
btw: don't forget to check the cleanliness of your air filter. A K&N flat drop-in is a nice, lifetime, upgrade: http://blackhaloracing.com/products-page/engine/intakes/
Rodlucci
10-26-2009, 12:33 PM
Great comments from all and you may want to consider changing your plug wires while you are at it. You have to disconnect them to change the plugs and coils anyway. I bought my plugs, wires and coils at Advanced Auto locally. All were NGK OEM parts and I believe the plugs were $20 each, wires were $32 for the set and coils were $22 each. I like dealing with Bricks and Mortar, but that is MHO!
nycgps
10-26-2009, 01:19 PM
Hey Guys,
wait a minute.
Last oil chanage at 52K and you're at 66K now? wow
If its true. You dont need to change your oil anymore, Cuz your engine gonna go kaboom anyway.
Huey52
10-26-2009, 01:55 PM
Coil location:
EDIT:
ken-x8
10-26-2009, 05:16 PM
wait a minute.
But he made it beyond 48303. Makes one wonder who should be counseling who. :evil_laug
Ken
nycgps
10-26-2009, 05:28 PM
Ken
if I didnt ask for compression test. I wouldn't know.
engine starts, runs, no problem. but it failed test.
yours could be having problems too. you just dont know it. Butt dyno never works.
tamz273
10-27-2009, 04:12 PM
Wow, left for the weekend and im back to the post to find out that my car is gonna blow? Any way of finding out when/how much longer it has on it before it goes "kaboom"?? Im doing the oil changes along with the plugs coils wires this weekend. Are you saying that I should look into selling the car BEFORE it goes "kaboom"???
REsuperD
10-27-2009, 04:21 PM
just change the oil now
and be care to not overfill. the renesis only drains ~1/2 of the oil. don't pour in the *normal* 5qt. it takes only 3.7
ken-x8
10-27-2009, 04:42 PM
Just don't let nycgps take it in for a compression test. :)
Ken
Huey52
10-28-2009, 07:03 AM
Just don't let nycgps anywhere near it - bad '8 karma. But then, he's a New Yorker, so .....
Go Yanks (hey, if the Sox can't be in it ....) ;)
tamz273
10-28-2009, 09:55 AM
Haha alright. Ill make sure I dont run any compression tests on it! I was still wondering though, if theres any way to find out how much time/milage I have left on my engine...?
As for the Sox vs Yanks, im not really a baseball fan.. Going to watch the Bruins vs Canadians on the 5th of Nov!!
Huey52
10-28-2009, 10:05 AM
Beyond a compression test, the only way to truly get an idea for how much time the engine has left would be to have it completely broken down by a rotary expert (e.g. MazMart) and even then it would be an educated guess. And if broken down it may as well be rebuilt, so .....
nycgps
10-28-2009, 10:28 AM
BrrwWAAaAArrrr ! Someone mentioned my name ?!?!?!
tamz273
10-29-2009, 09:11 AM
hahaha, only in good thoughts NYCGPS!
On average, how much would a rebuild cost? And would I have to drive my 8 all the way there?
tamz273
11-03-2009, 10:09 AM
Alright, so after doing all the oil changes, my wires plugs and coils, the car feels SO much better! Feels like im driving a brand new car! I LOVE it!! I replaced the Mazda Tranny fluid with the RL MT-90 and shifting is MUCH easier. Not sure who said that shifting will be harder, its not at all! The car all in all feels a WHOLE lot smoother and the shifter isnt vibrating anywhere near as much as it was before i changed everything out.
Thanks for all the help guys! Couldnt have done it without you all!
Huey52
11-03-2009, 10:17 AM
Changing the 'plugs in particular gives a 'new car' feel. Well done tamz.
