View Full Version : Did I just read this right?
Hercules
01-11-2003, 10:46 PM
http://www.rx8forum.com/attachment.php?s=&postid=21041
250 horsepower, and 216 torque??!?!?
*is confused*
Zio
01-11-2003, 10:48 PM
probably newton meters my friend
fritts
01-11-2003, 10:50 PM
216 NM or 159 lb-ft
maxcooper
01-11-2003, 10:51 PM
That would be nice, but the mazdarx-8.com site says 164 (auto) or 159 (manual), and that is much closer to what has been reported in the past. I tend to believe the 160 numbers.
The last RX-7 had 217 lb-ft of torque, so perhaps the sheet just has some of the old numbers. Or they saw 255/217 and only knew the HP in the marketing department, so they listed it as 250/216. Anyway, it is almost certain to be a mistake.
-Max
Hercules
01-11-2003, 10:53 PM
Thanks very much folks for the clear up there :)
rotisserie
01-11-2003, 10:55 PM
I just posted that in the other thread. I wish it tru though.:(
SpreeGuy
01-12-2003, 03:08 PM
Doesn't the SAE standards for engine Torque get measured in Ft Lbs?
Example (http://www.nutsandvolts.com/rx7/Engine.asp)
Quick_lude
01-12-2003, 03:24 PM
It is I think.. this looks like someone didn't convert Nm to FtLbs. Those are definitely Nm torque numbers.
rotisserie
thats what I thought:(
BryanH
01-13-2003, 01:08 AM
I'm surprised that no one has yet mentioned (that I'm aware of) these RX-8 spec sheets are saying Premium fuel is required!
IGOZMZM
01-13-2003, 01:20 AM
The spec sheet only states that Premium fuel is recommended, the "minimum fuel requirement" is blank.
Quick_lude
01-13-2003, 02:47 AM
Will the Renesis put out less power if lower octane is used? In my car with regular gas the ecu retards timing and reduces power output.
