View Poll Results: Do you have the Clutch Pedal Reinforcement Bracket installed?
Yes, I have the bracket reinforcement.
14.71%
No but I plan on buying one.
38.24%
No and I don't plan on buying one.
47.06%
Voters: 34. You may not vote on this poll
Clutch Pedal Reinforcement - Yes or No?
Old Oct 14, 2009 | 04:42 PM
416to212's Avatar
Utopia Taco Bell
Just curious to know if you guys have bought the Clutch Pedal Reinforcement Bracket or not.
Mine creeks occasionally, but I'm wonder if this means that my bracket will necessarily fail.
Old Oct 14, 2009 | 04:43 PM
dozer's Avatar
on his 3rd rx8
i just welded my bracket
Old Oct 14, 2009 | 04:51 PM
Flashwing's Avatar
3-wheeler
The weakness in the pedal assembly is because of the welds. Have the pedal re-welded and it will solve the issue.
I would suggest getting this done even if you are not having any issues with the pedal.
Old Oct 14, 2009 | 04:53 PM
ken-x8's Avatar
There are three possible reasons for a creak:
1. About to fail
2. Cut switch
3. Needs lubrication
I was on the verge of ordering one, but my inner cheapskate took over. Still have a year of B to B left. I figure that by the time that's up NHTSA will have ordered a recall and money on the bracket would be wasted. Also not keen on drilling a hole in my original pedal assembly.
Ken
Old Oct 14, 2009 | 05:30 PM
CyberPitz's Avatar
Huge hole is huge
Mine squeaks VERY rarely, so I am just chalking it up to lube. I have an 07 with less than 20k miles, so I'd have to assume the bracket isn't getting weak. No side to side play, either.
Old Oct 14, 2009 | 06:23 PM
Low Fly'n 8's Avatar
What kind of lube and where to apply it?
Old Oct 14, 2009 | 06:38 PM
epikeddie's Avatar
I would use White Lithium Grease since its residue is a bit cleaner and doesn't gunk up like WD-40 or other variants.
Old Oct 14, 2009 | 06:46 PM
mysql101's Avatar
mine is reinforced and it creaks. It needs to be lubricated.
The sign your peddle is failing is when your clutch starts leaning towards your brake peddle (as the brackets bend).
Hearing a noise isn't going to tell you anything.
Old Oct 14, 2009 | 11:15 PM
ken-x8's Avatar
Here's a question;
With the idea of removing the pedal, having it welded, and re-installing it being a very cheap and easy preventive fix why are so many people reluctant to even bother with it?
Not to downplay the failures, but probably because most of them don't fail.
Ken
Old Oct 15, 2009 | 01:12 AM
RotaryResurrection's Avatar
kevin@rotaryresurrection
Mine squeaked shortly after my MT swap, so I figured the clutch pedal was weak (it was from a semi-high mile car) and had it rewelded. Put it back in, bastard still squeaks. Put in a new slave and master, lubricated the ball end of the slave. Bastard still squeaks. I must assume it is in the clutch at this point.
The point is, just because the pedal makes a little noise or creak, doesnt mean it is about to fail. Noise and tactile sensation can be transmitted through the pedal from anywhere all the way to the pressureplate.
I agree that it is never a bad idea to reinforce the pedal even if you have no symptoms of failure.
Old Oct 15, 2009 | 04:32 PM
416to212's Avatar
Utopia Taco Bell
I'll take the advice of removing it an getting it welded just in case. This has been a very helpful thread.
Old Oct 16, 2009 | 02:29 PM
mbentley's Avatar
zoom-zoom
i voted "No and I don't plan on buying one." seems a little pointless with an automatic
from the sounds of it, if i had a manual, i'd buy one especially if i have wobble on the x-axis.
theblinkof
Oct 4, 2023 05:24 PM
mdl0209
May 23, 2019 05:46 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
