Track Day = Oil Change?
Old Oct 8, 2009 | 08:55 PM
milesprwr's Avatar
Hi All,
After the recent track day - I'm thinking an oil change is in order. Running Castrol 5w20 and ambient temperature was right around 100 degrees F. At these temps I imagine oil temperature would be nearing the point where conventional oil begins to break down (someone said they were reading oil temps exceeding 260 degress F).
I suppose my next question is, if I ran synthetic oil instead of conventional, would an oil change after every track event be necessary (due to the greater heat tolerance)?
Thanks in advance!
Old Oct 8, 2009 | 10:30 PM
expo1's Avatar
He's as bad as Can
I would rather change the oil right BEFORE the track event than after.
Old Oct 8, 2009 | 10:32 PM
kersh4w's Avatar
Hit & Run Magnet
^ +1
Old Oct 8, 2009 | 10:36 PM
Flashwing's Avatar
3-wheeler
Originally Posted by milesprwr
Hi All,
Thanks in advance!
If you are running oil that has been in the motor for a couple thousand miles and then running a track day then I would for sure change the oil after the track day. I agree with Expo that an oil change before the track day would probably be better.
I would be pretty surprised if your oil temperatures were 260 degrees as you would more than likely have blown your motor. Since oil plays a larger cooling role with the rotary engine you will see oil temperatures follow coolant temps. As such, if you had oil temps that high it's a sure bet your coolant would have been the same. The coolant seals tend to go out around 260 degrees. So, I don't imagine your temps were that excessive.
That being said, I would highly suggest changing your oil before the track day if you are going to be using a 5w-20. If you are expericing temperatures north of 220 degrees I would highly suggest a thicker viscosity.
Old Oct 8, 2009 | 11:33 PM
milesprwr's Avatar
Thanks for the info - any opinions of synthetic vs conventional for track days?
Old Oct 9, 2009 | 12:51 AM
kersh4w's Avatar
Hit & Run Magnet
whatever.
just do one before or after.
personally, i always run 5w-30 mobil1 full synthetic.
Old Oct 9, 2009 | 01:17 AM
Symbioticgenius's Avatar
You Dumbass!!!
before and after. You'd be shocked how dirty oil can get after a good track day.
Old Oct 9, 2009 | 01:26 AM
Krazed_Rx8's Avatar
^ +1
Old Oct 9, 2009 | 12:06 PM
tmak26b's Avatar
After a good track day, half your oil will be new anyway as you have to keep pour oil in there. I think the rate is 1 quart for every 75 track miles. I never keep it that low as I am afraid of oil starving under high G loads. I just pop the hood open after every two sessions
Old Oct 9, 2009 | 11:11 PM
Pico's Avatar
It's Complicated
+2 change before and after
Skyl3r
Dec 2, 2019 04:51 PM
Pelleilee
Sep 29, 2019 10:07 AM
jay_tibo
22
Sep 13, 2016 08:10 PM
FERRET
West RX-8 Forum
Jul 22, 2015 02:25 AM
