CEL frequently switches on/off
Old Oct 7, 2009 | 02:05 PM
The Louche's Avatar
My CEL came on about a week ago after getting gas. Didn't pull the code, but I tightened my loose gas cap and the CEL turned off shortly there after. Same basic scenario occured a few days later, again fixed by tightening gas cap.
My CEL came back on yesterday, however, despite the fact that it had been 2+ days since gassing up. Has anyone heard of a gas cap going bad and/or losing its ability to tighten properly with age and use (my car has @ 65K odo)?
I really hope this is just the gas cap and not something bigger...
Old Oct 7, 2009 | 02:08 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Yes.................please do a search(use advanced search) and you will see that this is a known issue. Most times a new cap solves it, but I have heard of one person that had to have the filler neck replaced.
Make sure when you put it on that you at least hear it click about 5-6 times!
If this CEL happens to pop on and flash then go off when you are redlining the car, then it's most likely a misfire and you need to look at coils, plugs, and wires.
Old Oct 7, 2009 | 02:18 PM
05rx8mazda's Avatar
B.I.G
Mine flashed when im not even red lining the car.. THe code i pulld up was p0300. Pull the codes at auto zone or something and if you have the same code let me know how you fixed it!!!! lol
Old Oct 7, 2009 | 02:21 PM
get the code pulled to verify the issue.
I always use the 3 click method and it hasn't let me down yet.
Old Oct 7, 2009 | 02:30 PM
Mazurfer's Avatar
Random misfire.....I'm sure you know that and you don't have to be redlining to get this. This is still usually coils, plugs, and or wires.....especially if you haven't changed the plugs or coils and you have 30k+ on your car!
Old Oct 7, 2009 | 03:08 PM
The Louche's Avatar
Glad to know the gas cap is the likely culprit. I don't think this is connected to playing about near the redline at all. I don't redline my car all that often now that I have 4 new points on my license.
Old Oct 7, 2009 | 03:13 PM
Mazurfer's Avatar
Well......you can go to an Autozone or somewhere and get the code read and then we will know for sure.
RACESHARK's Avatar
I had the similar problem, when I pulled the code, new gas cap,problem solved.
Old Oct 7, 2009 | 03:21 PM
Mazurfer's Avatar
Gas cap code......if I remember correctly is:
P0442 EVAP system leak detected (small leak) ON 2 EVAP system
CTrx8's Avatar
space for rent
redlining doesn't mean speeding or driving recklessly and will help your engine last longer.
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Jst4fun
Mar 5, 2021 07:16 PM
mdl0209
May 23, 2019 05:46 PM
Evan Gray
Sep 26, 2015 12:30 PM
