Question about redlining . . .
Old Oct 6, 2009 | 09:46 AM
stepatee's Avatar
New RX-8 Owner
This may have been asked elsewhere and may be a dumb question, but . . .
This morning I was driving to work, and went into the redline area while cruising around someone. Is it bad to go into the redline area, or is it ok as long as you don't drive for a long time in it?
P.S. I'm new to the whole six-speed manual -- only had the RX-8 for a week.
Old Oct 6, 2009 | 09:47 AM
chino0314's Avatar
rx8s are redline happy engines and need to be redlined but dont keep it there too long
Old Oct 6, 2009 | 09:49 AM
dozer's Avatar
on his 3rd rx8
you can keep it there, but not for a long time, you can bounce on it all you want....when i redline i usually shift closer to 9.5k with no problem
JinDesu's Avatar
went back to srsly broke
Redlining the car is good. Staying in the redline for an extended period of time wouldn't be so good for your transmission, but it's no big deal for your engine.
You want to redline the car at least once a day, and you can hold it for several seconds too. It helps your car breathe.
Old Oct 6, 2009 | 09:50 AM
StormyWankel's Avatar
EVOLVChicago.org
I like to just drive around in first gear at 9k RPM...it really lets my engine breathe...give it a go some time
Old Oct 6, 2009 | 10:00 AM
JinDesu's Avatar
Lol, people nearby must love you driving by :D
Old Oct 6, 2009 | 10:52 AM
EVOLVChicago.org
I am my neighborhood's alarm clock....in all seriousness, it has been said a billion times before...a red-line a day keeps the carbon away*...
*Disclaimer: My previous post was a joke that may not be obvious, having re-read it. Please do not subject your car to gratuitous and constant redlining as your trans will likely end up screaming "F YOUUUU!" as it drops out of the bottom of your car. Also, please keep your safety and the safety of those around you, as well as the local speed ordinances, fresh in your mind when you are administering your daily dose of red-line...carbon doesn't matter if you can't drive your car.
Old Oct 6, 2009 | 10:59 AM
Redline is ok for this engine, it does not suffer the same problem as the piston cousins.
Old Oct 6, 2009 | 11:02 AM
alfy28's Avatar
yep its fine. infact i redline at 10. you get the most power between 9.5k to 10. it kicks in like Taboo
Old Oct 6, 2009 | 11:27 AM
DarkLord7854's Avatar
Software Engineer
As long as ITS OVER 9000!!!!! you're doing good.
Old Oct 6, 2009 | 11:51 AM
813KR$'s Avatar
when you get up in the rpms too high the water pump cavitates and doesnt allow proper flow of coolant. As long as it is not held for extended periods of time, your good! As everyone above has mentioned . . .
Old Oct 6, 2009 | 12:21 PM
stepatee's Avatar
New RX-8 Owner
Thanks everyone for the quick responses. Mine beeped at me when I redlined this morning, made me nervous -- maybe I'll try it again on the way home
Old Oct 6, 2009 | 12:33 PM
adamwzl's Avatar
<3's Bunnies
That will be the redline indicator, young padawan.
Old Oct 6, 2009 | 12:35 PM
EMart11b's Avatar
Bang Bang
Pretty sure the engine peaks at 8.5...
Old Oct 6, 2009 | 12:42 PM
Software Engineer
It's supposed to.. I'd be more worried if it didn't.. the joy of the RX8 is hitting that beep and then taking a corner
Old Oct 6, 2009 | 12:43 PM
adamwzl's Avatar
<3's Bunnies
my peak power is when it just hits 10k I feel something going on, that means more power right?
Old Oct 6, 2009 | 12:47 PM
Gr8Bullet's Avatar
Im Sir Earl of Sandwich!
red lining FTW!!!! with catless pipes!
Old Oct 6, 2009 | 01:02 PM
Bigbacon's Avatar
2006 WB AT
suppose to make it beep... thats telling you that you just did your good deed for the day.
Old Oct 6, 2009 | 01:45 PM
stepatee's Avatar
New RX-8 Owner
OK -- I took it out at lunch, let it beep at me once or twice. Just feels so unnatural . . . just takes time I guess
Old Oct 6, 2009 | 01:47 PM
The Reverend's Avatar
That's a lie
After a while the beeping will make you feel happy in the pants
Old Oct 6, 2009 | 02:04 PM
The_Beast's Avatar
Mo' Money
I always understood that since the peak is at 8.5, if you shift at 9500 or higher it will land you back in that peak range, thus giving you a bit more push when you shift. Does anyone know if this is right, or is it optimal to shift at 8500-8700?
Old Oct 6, 2009 | 02:09 PM
HockeyRX-8's Avatar
TNC
redlining will blow your motor to pieces....DONT DO IT!!!!!!
.....j/k
Old Oct 6, 2009 | 02:18 PM
Gr8Bullet's Avatar
works for me....
Old Oct 6, 2009 | 03:08 PM
stepatee's Avatar
New RX-8 Owner
HockeyRX-8 -- you almost had me convinced that everyone else was lying to me! I'm still that nervous about shifting in the "red zone"!
Old Oct 6, 2009 | 03:11 PM
dozer's Avatar
on his 3rd rx8
trust us, redline is ok, this isnt a piston engine, you arent gonna mess anything up
