JFranco
10-05-2009, 11:43 PM
Yeah I know you can throw me with whatever you have got in your hands, but here is a noob question... WTF is premixing????? does it realy work? Sould I use the same kind of oil that is in the engine??? Thanks... :Peace:
View Full Version : Retard noob question (premix) JFranco 10-05-2009, 11:43 PM Yeah I know you can throw me with whatever you have got in your hands, but here is a noob question... WTF is premixing????? does it realy work? Sould I use the same kind of oil that is in the engine??? Thanks... :Peace: RyansRx8 10-05-2009, 11:45 PM ha loser what a retarded noob question lol jk I actually don't know either anybody want to help us out? JFranco 10-05-2009, 11:47 PM ha loser what a retarded noob question lol jk i actually don't know either anybody want to help us out? lol 05rex8 10-05-2009, 11:50 PM Idemitsu Racing Rotary Fuel Lube (Premix) - Synthetic Blend Inherently with many rotary engines, the entirety of the rotor and housing are not being sufficiently lubricated, resulting in premature wear or damage. In order to increase lubrication within the engine, Idemitsu developed Idemitsu Rotary Premix. At 1/2 oz per gallon of fuel, it is a cost effective way lubricate more of your engine and prevent premature catastrophic damage. A special blend of base oils reduces deposits and subsequent exhaust port clogging. As a result, your rotary will maintain the power at which it was designed. Special detergent/dispersant additives keep your fuel injectors clean to reduce maintenance. Provides additional lubrication for apex and side seals to increase seal life and increase efficiency of engine. Special additives allow for better sealing of the chamber, creating greater efficiency and more power. http://www.mazdatrix.com/q-supply.htm you pour it in the gas tank next time try the search function. xun4gvn4everx 10-05-2009, 11:50 PM It is putting oil into your gas tank like you would with a 2 cycle motor. Do not use the oil in your engine, there is specific stuff you buy that is called premix. Search premix and you will find endless threads on this. some say do, some say dont. Its a personal opinion. expo1 10-05-2009, 11:52 PM The second sticky post in the very same forum you posted is is devoted to this subject. http://www.rx8club.com/showthread.php?t=99636 The simple answer is if you have an 2004-2008 and plan on keeping the car a long time you should premix ( mix a certain type of oil with your fuel ). The details can be found it the above mentioned thread. I use 4oz of Idemitsu per 13 gallons of gas. JFranco 10-05-2009, 11:53 PM Thanks guys... JFranco 10-05-2009, 11:54 PM The second sticky post in the very same forum you posted is is devoted to this subject. http://www.rx8club.com/showthread.php?t=99636 The simple answer is if you have an 2004-2008 and plan on keeping the car a long time you should premix ( mix a certain type of oil with your fuel ). The details can be found it the above mentioned thread. I use 4oz of Idemitsu per 13 gallons of gas. What makes the 2009 and later different?? expo1 10-05-2009, 11:56 PM What makes the 2009 and later different?? Mazda realized there wasn't enough oil being added to the center of the rotors and added a third nozzle. That doesn't help us 04-08 owners which is why many premix. 2009 RX-8 have a better system of adding oil to the engine than older RX-8's. They only way we can make up for the lack of the 3rd nozzle is premixing. JFranco 10-05-2009, 11:59 PM Mazda realized there wasn't enough oil being added to the center of the rotors and added a third nozzle. That doesn't help us 04-08 owners which is why many premix. Mine is 09 so I guess I should not wory that much huh? expo1 10-06-2009, 12:08 AM You have less of a reason to pre-mix than we do. But I would still do it, more positives than negatives. jessedrifter 10-08-2009, 01:46 AM i think someone should just make a diy premixing for noooooubs xun4gvn4everx 10-08-2009, 01:47 AM i think someone should just make a diy premixing for noooooubs I'll give ya a premix for n00bs :naughty: UrbanOcho 10-08-2009, 01:52 AM I'll give ya a premix for n00bs :naughty: :evil_laug sh1t rory you took the premix right words right outta my mouth:Eyecrazy: damnit, i love n00b threads. they help my post count cuz i know nothing and can add nothing and still bank numbers FTW!!! Easy_E1 10-08-2009, 01:58 AM :evil_laug damnit, i love n00b threads. they help my post count cuz i know nothing and can add nothing and still bank numbers FTW!!! I'm sure you know some things. The important things. :boink: jessedrifter 10-08-2009, 02:02 AM i know important things :fruit: mike[piston eater] 10-08-2009, 02:06 AM +1:fruit: Easy_E1 10-08-2009, 02:14 AM i know important things :fruit: ;3267302']+1:fruit: Fluffers! Sheeeesh. mike[piston eater] 10-08-2009, 02:19 AM i haz proof easy, next time your in so cal im gonna bring you some of my lady friends |
