o2 Code P0037 - Could this be triggered from over-filling oil?
Old Oct 4, 2009 | 09:35 PM
j67345's Avatar
Okay, I've searched all over this site & can't find a direct answer. It's probably right in front of my nose, but I'm just missing it.
Here's the deal...I've got a performance shop that I have work on my cars, and I brought my 8 in a couple weeks ago to have all the fluids flushed & an oil change while she was in there.
Everything was fine driving home, but the next day on my way to work the CEL turned on (solid). The code is P0037, and I know it is the rear o2 sensor.
Now...I've seen someone mention it on here, but is it possible that this whole o2 sensor problem may have been triggered from the oil being over-filled? Or is it probably just a coincidence that I threw a CEL the next time I drove it?
I'm not even sure if it was over-filled...the guy that normally works on my cars didn't do this work though, so I'm a bit skeptical (they always take GREAT care of my cars, but the dude that worked on it this time had a dirty hat on & ended up marking the roof liner up with oil stains from the bill of his cap! They did get them all out...)
Old Oct 4, 2009 | 09:44 PM
expo1's Avatar
He's as bad as Can
How many miles on your 8? The rear O2 does go out on older, higher mileage cars. Did you also inspect it for damage?
Old Oct 4, 2009 | 09:57 PM
j67345's Avatar
Just over 50k miles....I suppose not a ton of miles for an '04
Old Oct 4, 2009 | 09:59 PM
j67345's Avatar
hmmm....damage....I don't even know where the friggin o2 sensor is. I'll have to check into that tomorrow
Old Oct 4, 2009 | 10:45 PM
expo1's Avatar
He's as bad as Can
Only photo I have, its in the CAT in plain sight.
Old Oct 5, 2009 | 06:05 AM
j67345's Avatar
awesome, thanks! I'll have to take a look tonight after work. Thanks for that pic!!
Old Oct 17, 2009 | 03:26 PM
JWoody's Avatar
Rotary Obsession
if im not mistaken i thought the p0037 CEL is for O2 sensor bank 1 which would be the front one? whats funny about all of this is i got my oil changed and 4 days later my CEL came on with this same error. i swore it was for the O2 sensor b4 the cat.
Old Oct 17, 2009 | 03:29 PM
ferg's Avatar
lol damn
Old Oct 17, 2009 | 03:38 PM
Reset the ECU and see if it comes back
Old Oct 17, 2009 | 03:59 PM
JWoody's Avatar
Rotary Obsession
im sorry P0037 is the rear. P0031 is the front. im getting issues with the front. im hesitant to buy a $250 O2 sensor for the front and it not be the issue.
Old Oct 17, 2009 | 07:32 PM
j67345's Avatar
I did try to rest the ECU last week...unfortunately it didn't do anything. O2 Sensor doesn't look damaged, so I figure I'll just get another one. Bummer!
Old Oct 17, 2009 | 08:20 PM
EMart11b's Avatar
Bang Bang
o2 sensors die... your sensor's time has come
Old Oct 17, 2009 | 09:07 PM
9G Redline's Avatar
Trolling since 2004
That sucks that yours died so soon. My 04 has 104k on the clock and no issues *knock on wood* yet. Good luck fixing it.
Old Oct 17, 2009 | 09:21 PM
expo1's Avatar
He's as bad as Can
My rear O2 went at 119,000 FYI.
Old Oct 17, 2009 | 09:56 PM
9G Redline's Avatar
Trolling since 2004
Guess I'll be on the watch then. Wonder if an 02 mod and midpipe would be more worth it than replacing the sensor itself....we'll see when the time comes.
Old Oct 17, 2009 | 10:07 PM
Eelfinn_Ty's Avatar
My cel is on for this same reason. The rear o2 sensor isn't that important. It is just there to tell you if the cat is doing its job. I'm just ignoring it for now.
Old Oct 20, 2009 | 08:44 PM
Cam's Avatar
Cam
this space for rent
doubt its from the oil change. overfilled oil can damage the cat.
Silicone and lead (from leaded gas) kill 02 sensors.
With an o2 sensor its usually 2 things, the sensor, or the wiring.
gwailo
May 14, 2024 06:57 AM
Pelleilee
Sep 29, 2019 10:07 AM
Warrior777
Jun 24, 2019 04:47 PM
chris424
Sep 2, 2015 10:18 AM
wayloco
Sep 1, 2015 09:03 PM
