spring on ashtray assembly
Old Sep 26, 2009 | 10:19 AM
Alexb's Avatar
desperately needs a drop
So I think I've heard of this being common, but the spring that spring loads the door flap thing.
Well, mine fell out, and I don't know where it goes back in at. So can anyone tell me?
Old Sep 26, 2009 | 11:27 AM
jessedrifter's Avatar
so cal
ya ugghhh that happens to me all the time
Old Sep 26, 2009 | 11:41 AM
Alexb's Avatar
How do you fix it? I just don't know where the spring goes? can you give a little explanation?
Old Sep 26, 2009 | 11:56 AM
so cal
umm i know theres diagrams of of the ash tray assembly somewhere on this forum.
Old Sep 26, 2009 | 03:07 PM
BaCHeLoR211's Avatar
CaN't StOp Won'T StoP!!!!
yea mines is messed up too
Old Sep 27, 2009 | 07:52 AM
nuke0907's Avatar
Never Blend In
i had this problem too. fixed mine by getting an RB gauge pod.
Old Sep 29, 2009 | 11:44 AM
Nick's Avatar
Vance Refrigeration
On the right side if you are looking at it from the front, there are two little holes, one on the lid and one on the base. The bent tips of the spring go in these holes. Just try lining it up and you should be able to tell which way it goes.
Mine actually broke off, so I had to drill a new hole in a location close enough to the old one that the spring still worked.
It took me a few minutes to get it in but what I found worked was holding one end of the spring with needle nose pliers, putting the other end in first and then pushing it toward the other hole and lining it up, let it catch, and then push it in all the way.
I wish I'd taken pictures, but I didn't. If I feel like taking my center console apart again soon, I'll take some for you.
Old Mar 27, 2012 | 06:54 PM
Conundrum's Avatar
I just found out I have the same issue, but I didn't see the spring, where did you guys typically found yours at? Behind the assembly or close to the lighter...etc?
Old Jan 10, 2013 | 09:42 PM
gcthree's Avatar
Thanks for the tip. I drilled a hole and inserted the spring. Works perfectly!
Old Jan 11, 2013 | 08:44 AM
YUL PHL's Avatar
mine fell out..it just flaps up and down now. rarely use anyway
Old Jan 11, 2013 | 11:14 AM
twistedwankel's Avatar
Doug
+1 Just push it at the top to open no problem.
Old Jan 11, 2013 | 11:27 AM
YUL PHL's Avatar
i usually keep a snuff box in there.
great for a quick pinch or to refresh the air in the car (smells like rose water). the heat from the engine bay helps to release the smell
Old Jan 12, 2013 | 12:27 AM
Matrx8's Avatar
i haz rotary? say what?
What, you mean you smoke in your 8?
Old Sep 24, 2013 | 11:15 AM
Footman's Avatar
Dodging those Corollas
Where can I buy just the spring? I can't seem to find that part anywhere and I don't want to pay for the whole ashtray assembly just for the spring
duworm
Oct 1, 2015 04:57 PM
archon
Oct 1, 2015 06:08 AM
RotaryMachineRx
Sep 29, 2015 10:26 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
