Dyno of my RX-8
Old Sep 23, 2009 | 08:31 PM
rev29k's Avatar
Dyno of my RX-8
I took my stock RX-8 to the dyno a while ago just to get a baseline and see where it is at. I don't really plan to do any real power-adders since B Stock only allows cat-back exhaust.
And a comparison to my 300ZX with intake and exhaust. The RX-8 makes less peak power but has a much wider power band.
And video.
http://www.youtube.com/watch?v=kljPStSmGY8
Old Sep 23, 2009 | 08:39 PM
Brettus's Avatar
Boosted Kiwi
I see your problem ........................
Chadwisk's Avatar
Moar Low!
Awesome! Maybe since you aren't going to go for power add on's you should go for looks instead(that's the route I'm going for first). For example, lowering your car give it a really aggressive stance compared to stock, strakes from rotaryfx , or rotary chrome accents give it a new look too.
Old Sep 23, 2009 | 09:04 PM
rev29k's Avatar
Looking at the dyno results, I had a feeling something in my ignition system was a little off, I was thinking more of spark plugs.
I would like to lower it, but B Stock only allows shocks and front sway bar, which I will be doing. But I will get the rotary chrome accents, I like them.
Old Sep 23, 2009 | 10:42 PM
Man I need to get this new engine on the dyno with the BHR coils and the mid-pipe.
Old Sep 24, 2009 | 03:46 AM
@!!narotordo's Avatar
FLAME ON!
Old Sep 24, 2009 | 04:04 AM
da twistiez
Old Sep 24, 2009 | 04:57 AM
dmp's Avatar
dmp
RX8 and a Truk....
Was that 'corrected' hp? Don't use 'corrected'. You shouldn't car what your car would hypothetically make in whatever 'idea' circumstances the dyno thinks.
But - that's about standard, I suppose. Funny how Mazda passes off 210hp as 230, isn't it?
Old Sep 24, 2009 | 06:24 AM
shazy's Avatar
Better than mine.
Old Sep 24, 2009 | 06:46 AM
If I dyno less than 190WHP I will be bummed.
Old Sep 24, 2009 | 02:44 PM
Brettus's Avatar
Boosted Kiwi
Originally Posted by 9krpmrx8
I will be bummed.
by who ?
Old Sep 24, 2009 | 03:04 PM
RufusVonStorm's Avatar
Rev your torque looks good, if you replace your coils you should see another +10 peak hp or so
Old Sep 24, 2009 | 03:11 PM
by who ?
Old Sep 24, 2009 | 03:17 PM
Jon316G's Avatar
Grasshopper
Then you better prepare yourself for lower than expected numbers
My dyno run was only 190HP:
Old Sep 24, 2009 | 06:14 PM
AJ's Shinka's Avatar
Enthusiast
Attachment 145860
Isn't that stock HP numbers. What mods do you have? I give up, going esmiril turbo.
Old Sep 24, 2009 | 07:08 PM
TX
Attachment 145860
HP wise we should be pretty even so I will be okay with 190WHP.
Old Sep 24, 2009 | 07:21 PM
Jon316G's Avatar
Grasshopper
Mods are listed in my signature.
Couple factors still need addressed before I can say that is my "final" numbers.
I should have told the guy to red-line it instead of 8500 rpm because it appears that the power curve was still rising.
I also want to correct the AFR a tad.
Charles R Hill and I talked for awhile about that and he feels that I might have some "hidden power" waiting for the AFR to be corrected.
We also question the actual dyno itself (dynojet)... but I don't feel like spending more money at another dyno just to prove that point.
BillBertelli
NE For Sale/Wanted
Mar 19, 2016 03:01 PM
Brokegang
Jan 3, 2016 12:45 PM
05rx8mazda
Nov 28, 2015 09:42 AM
Tsurugi
Sep 7, 2015 08:27 PM
