17" Wheels w/ 225/45
Old Sep 23, 2009 | 01:15 AM
milesprwr's Avatar
Hi All,
I've picked up some 17" wheels for my 2nd track only set of tires. I know if I mount 225/45's on these wheels, I'll lose ~inch of the tires diameter (compared to stock). Besides an incorrect speedo reading and a similar effect of lowered gearing, what else can I expect?
Old Sep 23, 2009 | 01:22 AM
TopGear8's Avatar
mkuhnracing.com
It should feel a bit faster and will be more responsive
Old Sep 24, 2009 | 01:16 PM
TheWulf's Avatar
My 8 looks like a Smurf
Wouldn't it be slower because each tire rotation will travel a smaller distance?
Old Sep 24, 2009 | 01:24 PM
TopGear8's Avatar
mkuhnracing.com
^So by your theory, An RX8 with 22" wheels would be faster than a RX8 with 18" Wheels...
Lower gearing = Smaller Wheel/Tire = Quicker Acceleration
Old Sep 24, 2009 | 01:26 PM
ZumnRx8's Avatar
RX8 & RX7 owner
^mine does
Old Sep 24, 2009 | 01:27 PM
xun4gvn4everx's Avatar
True love is blue x2
except it takes more torque to rotate the 22" wheel versus the 18" wheel. So, yes, you do get more distance in one rotation, but it takes more force to get the wheel to rotate that far.
Old Sep 24, 2009 | 01:28 PM
ZumnRx8's Avatar
RX8 & RX7 owner
and we all know the 8's came with 300 ft/lbs torque...
Old Sep 24, 2009 | 01:31 PM
w00t w00t oh....wait....
Old Sep 24, 2009 | 01:32 PM
ZumnRx8's Avatar
RX8 & RX7 owner
^im busy making some motivational posters... did u see my scream one?
Old Sep 24, 2009 | 01:33 PM
nope, where is it?
Old Sep 24, 2009 | 01:47 PM
TheWulf's Avatar
Wheel size != tire size. I was talking strictly tire circumference. (In a condition where weight is not a factor and tire circumference is the only variable)
Speed = Distance / Time
Time is fixed for each rotation - drivetrain won't spin faster or slower if weight is unchanged. Distance is increased per rotation. Thus speed is increased.
If we add the weight variable, then it becomes fun and we get to do a few nice formulas to add up the impact of both variables at different points. I'd love to see someone draw it up but sadly I have other priorities.
FWIW, if you have a heavy 18" and a light 22" that weigh the same, it won't matter. The rim size is NOT a variable in this equation. The only variables are Tire Circumference and Wheel+Tire weight. Depending on the extent of the deltas of both of these variables from the stock setup, either one could have a higher impact than the other.
Chris Ryan
12
Mar 2, 2013 08:22 AM
Phlash
Jan 22, 2009 10:34 AM
the island
Jun 20, 2008 07:26 PM
