View Full Version : turbo maintenance
freaklinkmusic 09-20-2009, 01:32 PM im pretty close to deciding whether to go turbo or supercharger on my 6port 6speed auto. If I go turbo I will have the greddy kit (for the most part, some things will be interchanged)
couple of questions though
1. By looking at most greedy kit setups, It doesnt seem as if id be hard to changed sparks plugs... but what about the coils?? Is it a big hassle to disconnect some hoses (or do u even have to)??
2. Decarb.. If I decide to use the foam to decarb my engine, will it affect the turbo? I dont believe it will damage anything... but will it?
3. OIL. from what I understand synthetic oil is best for a turbo.As of right now N/A I am using 10w40 royal purple. I DONT PRE-MIX.. But I've been thinking about going back to 20w50 castrol NON-synthetic. I only have about 2000 miles on my engine. So basically my question is would it be alright for 20w50 mineral oil to be lubricating the turbo?? or should I just stick with 10w40 royal purple?
mysql101 09-20-2009, 01:46 PM the main thing is to not drive the car hard before you shut it down. If you do, the turbo will be really hot, and you will cook the oil in the turbo. synthetic will not cook as easily as mineral, which is one reason why it's recommended.
best bet is to go synthetic, and don't run the car hard for ~5 mins before you shut it off. some people opt for a turbo timer instead, but that isn't useful if you park in an enclosed space, like a garage.
freaklinkmusic 09-20-2009, 01:55 PM the main thing is to not drive the car hard before you shut it down. If you do, the turbo will be really hot, and you will cook the oil in the turbo. synthetic will not cook as easily as mineral, which is one reason why it's recommended.
yeh i wasnt gonna get a turbo timer. Im good at letting the engine simmer down (i even do that N/A) so i guess ill stick with Royal Purple
racerboy59 09-20-2009, 02:16 PM Don't you have to change your oil more frequently if you are turbo?? What's the recommended interval?
Brettus 09-20-2009, 03:19 PM 1. No problem to change coils
2.I never decarb but I,m sure it would not be a problem to just put the solution in AFTER the turbo .
3.I use 5w40 synthetic - synthetic is better for turbo use . Would not recommend 20w50 for our cars N/A or turbo but that argument is for another thread.
FazdaRX_8 05-26-2011, 01:53 AM So instead of starting a new thread i thought I would post in this one
I was wondering
If the oil change intervals increased?
Spark plug change intervals increased?
or anything else that I am missing?
shadycrew31 05-26-2011, 02:26 AM From what I hear
Engine rebuild intervals increase as well.
FazdaRX_8 05-26-2011, 03:46 AM LOL, have any other input?
monchie 05-27-2011, 01:39 AM From what I hear
New engine intervals increases as well.
FazdaRX_8 05-27-2011, 02:56 AM and this is why the search feature sucks
shadycrew31 05-27-2011, 10:32 AM I don't see why? Anything you'd need to watch out for has been mentioned.
1.the main thing is to not drive the car hard before you shut it down.
2.I use 5w40 synthetic - synthetic is better for turbo use . Would not recommend 20w50 for our cars.
3.Engine rebuild intervals increase as well, if you boost you are going to blow your engine faster so have an extra 5k sitting around unless you want ot try and rebuild the engine yourself.
As for oil change intervals I'd stick with 3000 miles, I've never done the recommended 7k, I think that's silly.
There's really nothing that special to watch out for unless you are running 20 pounds of boost and a monster setup. Most Greddy kits are pushing 5-8 psi so its not a big deal.
FazdaRX_8 05-27-2011, 11:45 AM With running richer in boost will carbon build up increase enough to warrent changing spark plug more often and or de-carbing the engine more often?
shadycrew31 05-27-2011, 12:54 PM unfortunately de-carbing doesn't get allot of the carbon out from the apex and side seal grooves. The carbon that builds up in there needs to be removed with a pick or a soft brush, it gets really caked on in there. You could soak it for hours and your still need a good amount of force to get it cleaned up.
Kinda sucks thats not a turbo thing though that's a rotary thing. so yes running richer will increase the amount of carbon building up in there. You might be able to keep it at bay and extend the life doing a seafoam treatment ever 3k but I can't guarantee that wont effect the engine in a negative way.
RX8Soldier 05-27-2011, 01:19 PM I'm assuming you've upgraded coils and wires? That will help with the combustion.
As for plugs, you could just check them more regularly to make sure they aren't fouled, give them a good clean and re-install.
FazdaRX_8 05-27-2011, 05:17 PM thanks shady, sound like we need nanobot to clean it up :)
Yes I have upgrade wires and bhr coils, and cooler plugs.
Its running great, I just wanna keep it that way :)
shadycrew31 05-27-2011, 05:50 PM thanks shady, sound like we need nanobot to clean it up :)
or a microorganism that eats it up!!
http://www.sciencedaily.com/releases/2003/09/030912073359.htm
