Clutch - what are the signs?
Old Sep 19, 2009 | 01:26 PM
daddyg's Avatar
How long do the clutches typically last on the car? I do about 80/20 highway city mileage and to my knowledge I'm not hard on the clutch.
My car is an 04 with approx 40K miles on it.
What are the signs your clutch is going?
Old Sep 19, 2009 | 01:56 PM
MazdaManiac's Avatar
Stand on the throttle in 4th gear.
If the RPM "runs away" after you cross 5000 or so without commensurate acceleration, the clutch is slipping.
Generally, you can get up to 100,000 miles out of an OE clutch on a relatively stock RX-8.
Old Sep 19, 2009 | 02:01 PM
Flashwing's Avatar
3-wheeler
I've got 87,000 miles on the stock clutch so it seems like it lasts a while!
Old Sep 19, 2009 | 02:10 PM
Silver06's Avatar
Zoom Zoom....
Hi.
Assuming you are not talking about mechanical failure of the pressure plate or release components, or oil contamination, but are just talking about normal wear of the friction material on the clutch disc, I agree with the guys above me as far as the test and lifespan (60,000 miles +++).
Generally, you will have more than adequate time between when you notice a clutch gently slipping on the highway, and when you have trouble with slipping in 1st gear. Therefore, clutches are an on-condition replace item, rather than a scheduled time/mileage item.
On a related note, please check your clutch pedal bracket for signs of metal fatigue / cracking in the area where it bolts to the firewall. Search for threads for examples. A broken pedal will leave you by the side of the road....
G'luck.
Old Sep 19, 2009 | 04:19 PM
scremn8's Avatar
the more things change
he could be burning his clutch a lot, that could account
for faster where.
Old Sep 19, 2009 | 04:23 PM
RACESHARK's Avatar
i just replace mine at 78,000. Mine was slipping the clutch and also the bearing was bad.
Old Sep 20, 2009 | 09:13 AM
Low Fly'n 8's Avatar
I also have 87,000 miles on the original clutch with no problems.
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Kim Jong Illest
Sep 4, 2015 04:27 PM
