Yet Another Sub Install
Old Sep 18, 2009 | 10:20 PM
bmak's Avatar
MA Yet Another Sub Install
I finished up my sub install this week. I've attached a few pictures documenting the 4 gauge cable run through the firewall to the battery, the grounding point I use for the sub amp (and a 4 channel amp), and the fitment in the trunk.
Attached Thumbnails Yet Another Sub Install-img_0041.jpg   Yet Another Sub Install-img_0044.jpg   Yet Another Sub Install-img_0045.jpg   Yet Another Sub Install-img_0046.jpg   Yet Another Sub Install-img_0047.jpg
Old Sep 18, 2009 | 10:22 PM
bmak's Avatar
More Photos
Attached Thumbnails Yet Another Sub Install-img_0048.jpg   Yet Another Sub Install-img_0049.jpg   Yet Another Sub Install-img_0051.jpg   Yet Another Sub Install-img_0054.jpg   Yet Another Sub Install-img_0060.jpg
Old Sep 18, 2009 | 10:23 PM
bmak's Avatar
Last set of photos
Attached Thumbnails Yet Another Sub Install-img_0061.jpg   Yet Another Sub Install-img_0062.jpg   Yet Another Sub Install-img_0064.jpg
Old Sep 19, 2009 | 10:39 AM
fannin522's Avatar
Fannins rx8
dude clean you car how did you connect your amp to the radio?
Old Sep 19, 2009 | 02:03 PM
WikkedOne's Avatar
Deals on wheels
Looks good! Nice clean looking install.. and if that's a ported box I bet it sounds GODD in there..
where did you put your amp, or amps? I'm assuming you have more than one amp because you have a splitter on your 12V+ line.. and I see you have a speaker terminal with what looks like 2 power leads going to it. how exactly did you hook it all up?
Old Sep 19, 2009 | 02:45 PM
bmak's Avatar
Complete equipment list:
  • Pioneer Premier FH-800BT Head Unit
  • Pioneer GEX-P10HD HD Radio Tuner
  • Metra Turbo2 Head Unit kit
  • Kenwood Excelon XR-4S 4 channel amplifier
  • Kenwood KAC-8104d 1 channel mono amplifier
  • Infinity Kappa 60.9cs Component speakers (front doors)
  • Infinity Kappa 692.9i 2-way 6x9 speakers (rear deck)
  • Custom 10" ported subwoofer enclosure (built by SRQ Customs)
  • JL Audio 10w3v3-4 10" subwoofer driver
  • 4 gauge power cable - Knuconcepts
  • 8 gauge power cables - Knuconcepts
  • 4 gauge distribution block - Knuconcepts
  • 8 gauge ground cables - Knuconcepts
  • 4-channel RCA cable - Knuconcepts
  • 2-channel RCA cable - Streetwires ZN5
  • Assorted hardware/tools
Old Sep 19, 2009 | 03:05 PM
bmak's Avatar
The speaker cup that you see in the first picture is actually for the inside of the subwoofer box. I posted that pic to show an alternative method of cabling the subwoofer other than the quick disconnect cables that fit on the flat tabs or soldering which doesn't work as well with larger cables. The cables in that photo are 10 gauge speaker wire.
The 4 channel amplifier is mounted to the bottom side of the rear deck, pretty much in the same location that the factory bose amp was previously mounted. There is a metal channel running around the back side of the rear deck that is just perfect for running all the power, speaker, rca cables, etc.
The mono amplifier is mounted on the back of the sub box right in the center. This allows me easy access to adjust and tweak the amp settings through the middle storage compartment. It is generally considered a bad idea to mount an amp to a sealed subwoofer enclosure because the internal pressure from the sub makes the walls flex as the subwoofer driver compresses and decompresses the internal air, but this should be less of an issue with a ported box as the internal pressure does not change as drastically (due to the port).
The RCA cables and the front speaker cables run down the center armrest console area between the trunk of the car and the head unit; the front speakers continue running through the dash area through to the doors where the front speakers are mounted.
You can see, in the second set of photos, where the 8 gauge cables are grounded to the chassis on the rear passenger side of the center console behind the back seats.
When completing the installation, I left the two plastic panels separating the trunk from the back seat out of the car as they will likely be nothing more than a potential source of rattling and they are no longer needed to be the finish on the front end of the trunk.
If anybody has specific questions on any part of the install, I'm happy to explain in as much detail as needed. I kept the comments in this post with relatively little detail for brevity's sake.
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Zube6115
Sep 30, 2015 12:57 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
