Series I Do It Yourself Forum Wanna save some coin or time/money in the shop? Read up on Do-It-Yourself custom mods and repairs & post your own here.
DIY: Rear brake Bulb Replacement
Old Sep 18, 2009 | 11:30 AM
Sand-eye's Avatar
ON DIY: Rear brake Bulb Replacement
Is there a DIY on replacing the brake light bulbs for the RX-8?
Also, I have purchased LEDs to replace the bulbs (Brake, Reverse and Turn) - do a I need a resistor for the turn signal LED repalcement if I'm not replacing the front turn signals with LEDS?
Tks
Old Sep 18, 2009 | 07:48 PM
Blazed's Avatar
I believe the instructions are in the owners manual. Its very easy, just open your trunk, remove the inner trim from the back, and you can see the light sockets from there. Twist them to remove and just pull out the bulbs.
I believe you need resistors for the turn signals otherwise they will blink double speed.
Old Sep 24, 2009 | 12:57 PM
Sand-eye's Avatar
Thanks for the tips. I'll have a look in the owners manual.
Old Sep 24, 2009 | 01:41 PM
Huey52's Avatar
Registered Zoom Zoomer
Check the DIY here on rear bumper removal and you'll see the bulb connectors. As Blazed cites you just need to peel back the trunk liner by removing a few poppet screws and he connectors are easily accessible.
https://www.rx8club.com/showthread.p...IY+rear+bumper
Also see the owner's manual.
Old Sep 28, 2009 | 07:08 PM
Sand-eye's Avatar
It appears V-LEDs shipped me the wrong LED for my turn signals! I have contacted them and they will ship out the amber LEDS.
I installed the rest of the LEDS for the tail lights and no problemo! However, I see that although the bulb can be inserted in the socket it actually only lights up if placed presumably with the correct polarity so I had to switch the LEDS if they did not light up immediately.
Regarding the resistors for the turn signal is this something I can get at The Source or is this a speciality item I need to order from V-LEDS? (I did plug in the red brake LEDs just to test them out an I noticed the quick turn signal flashing so I'm thinking I will need a resistor)
jay_tibo
22
Sep 13, 2016 08:10 PM
20b-3rotor
Sep 2, 2015 11:09 AM
CARBONRX-8
Aug 23, 2015 09:52 PM
thewatcher101
Jul 27, 2015 09:44 PM
