Issue: Too much compression
Old Sep 16, 2009 | 10:46 AM
Daniel K's Avatar
Hi everybody,
my engine works fine, I only recognized (maybe once a month) that the sound changes a little bit (above 100mph) - but only when it's really hot outside (this sound appears and goes away for more than 3 years now!).
So I went to my dealer today and asked him to check the compression, result:
12,8 10,4
12,8 14,5
14,9 12,5
(results in bar)
for reference, regular compression is around 6,9-8,5bar.
Can anybody imagine what this means in detail - maybe someone here with an similar problem?
Thank you very much for your help (I'm really lost at the moment :-( )
Old Sep 16, 2009 | 10:59 AM
some seals are stuck.
Old Sep 16, 2009 | 11:24 AM
I would question that the tester is working correctly.....
Also why are the results in 3 rows? Should be 2 rows of three entries to make sense with an RPM reference for each row??
Old Sep 16, 2009 | 01:59 PM
Daniel K's Avatar
Hi there,
3 rows due to 3 "areas" from each rotor.... all measured with Starter RPM
"Tester?" That was my first question at my dealer (they measured some other RX8 with this test equip as well - without any trouble - I think if there would be something wrong, the test results must be lower, not higher?)
@nycgps: What seals exactly do you mean, any clue? Is there a chance to clean the engine?
THANKS!!!!!
Old Sep 16, 2009 | 02:07 PM
Brettus's Avatar
Boosted Kiwi
Possibly you have a boat load of carbon in your combustion chambers ?
Do you redline often ?
Old Sep 16, 2009 | 02:41 PM
Daniel K's Avatar
Yep, I love my redline (minimum two times a day ;-) )
So normally no reason for carbon...?
WHAT IF I JUST CONTINUE RUNNING THE ENGINE? (so far 60000 miles reached)
Will this pressure (compresion = more than 210 PSI within the engine) destroy the engine????
Old Sep 18, 2009 | 09:26 PM
maybe in your brain since it apparently has severe compression loss
looks like they're using kgf/cm*2 units (note that 10.2 kgf/cm*2 = 145 psig), what was the cranking RPM?
Old Sep 19, 2009 | 12:19 AM
blah
Old Sep 19, 2009 | 02:49 AM
arghx7's Avatar
Take your life.
Old Sep 19, 2009 | 03:14 AM
Daniel K's Avatar
Cranking speed was 290rpm....
so thats still 210 psi (my bloody measurement) against 130 psi (acc. your table)... :-) :-( ???
Old Sep 19, 2009 | 09:40 AM
Sticky seals will not raise compression...either the tester was wrong, or there is a horrid buildup of carbon on your rotor faces causing the tubs to be way smaller...this is unlikely because with that much carbon there would be seal issues as well......
Oh...did I say that the tester is likely wrong
Or you have a great motor and have nothing to worry about....
Or you have a blockoff plate on your exhaust
Old Sep 19, 2009 | 03:02 PM
people cant get joke these days ...
Old Sep 19, 2009 | 04:12 PM
Well... with an alarm going off all the time with flashing lights...........
gwailo
May 14, 2024 06:57 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Hiroshima_RX
Sep 21, 2015 06:28 PM
