Feras
09-12-2009, 01:44 PM
is this a relatively easy modification? and is it essentially universal, found a bunch of diy's but none specifically for my vehicle. Doing boost and AFR on a WRX so not an RX-8 i know but still a little guidance maybe?
View Full Version : installing gauges Feras 09-12-2009, 01:44 PM is this a relatively easy modification? and is it essentially universal, found a bunch of diy's but none specifically for my vehicle. Doing boost and AFR on a WRX so not an RX-8 i know but still a little guidance maybe? StealthTL 09-12-2009, 01:49 PM Vacuum gauge on a WRX would need a 'tee' fitting in the line to your blow-off valve on the intercooler. O2 ratio would need a new bung in the downpipe, or use the existing O2 sensor hole underneath. S Jedi54 09-12-2009, 01:52 PM hey Feras, the Subbie forums are thatta way. ----------> ;) Feras 09-12-2009, 01:57 PM haha, ya their DIYs and people aren't as awesome as here...and frankly i trust you people more with mechanical knowledge. thanks stealth i'll take a look at that, and maybe i ought to get the service manual, before i start drilling holes in my firewall lol Jedi54 09-12-2009, 02:01 PM no way their lounge is a much fun as ours. That's what keeps you coming back, isn't it... I think Stealth nailed in the head but once you get that done, the rest is pretty standard. Just find a way to run the wires, make sure you've got good grounding points on any sending units and you should be good to go. Where are you mounting the gauges? I haven't sat in a WRX in forever so I need pix. As for the owners manual: can you DL it from subaru's website? If not, I'm sure SOMEONE'S got it floating around their forums. (at least I would hope so) Feras 09-12-2009, 02:15 PM yeah the manual should be easy...im getting a cluster that mounts 2 guages on the steering column from perrin performance...looks pretty awesome in theory. Just trying to figure out how much in total the project's gonna run me. I figure since i plan oninstalling a cobb with some sort of moderate stage 1 tune which nets about 60hp and 75lbs of torque i might as well be able to see some of those differences so gauges it is. Jedi54 09-12-2009, 02:19 PM I figure since i plan oninstalling a cobb with some sort of moderate stage 1 tune which nets about 60hp and 75lbs of torque i might as well be able to see some of those differences so gauges it is. I hate you. Did I ever tell you that? :lol2: NOTURX8 09-13-2009, 11:02 AM lmao |
