fcfdfeman
09-10-2009, 07:17 PM
I'm planning on racing in th estock class in SCCA. I was looking at the Racing Beat springs set for the front and rear. Does anyone use these springs and if not what springs do you guys prefer.
View Full Version : Springs fcfdfeman 09-10-2009, 07:17 PM I'm planning on racing in th estock class in SCCA. I was looking at the Racing Beat springs set for the front and rear. Does anyone use these springs and if not what springs do you guys prefer. dhan 09-10-2009, 07:22 PM Well if you want the lowest go with the sprint springs :). then again lots of people go with tein's either one works fine Pico 09-10-2009, 11:37 PM Look into the correct spring rates your looking for. Many companies offer more than one model based on the type of driving performance your looking for (street/track). Once you choose a set of springs you may want to look into beefing up your sways- depending on how stiff your looking to go. swoope 09-11-2009, 05:48 AM I'm planning on racing in th estock class in SCCA. I was looking at the Racing Beat springs set for the front and rear. Does anyone use these springs and if not what springs do you guys prefer. that is a very good choice for the estock class. racing beat got it right. if you have any other questions. pm me. there are a couple of others that are good. beers :beer: StrokerAce 09-12-2009, 10:58 AM I'm planning on racing in th estock class in SCCA. I was looking at the Racing Beat springs set for the front and rear. Does anyone use these springs and if not what springs do you guys prefer. If you're planning on autocrossing in B Stock you can't change springs. NoRotorNoMotor 09-12-2009, 01:40 PM Yup ^ You can install shocks in the stock class. (Koni yellows) (or similar) fcfdfeman 09-15-2009, 09:20 AM I thought you could race in B stock with an upgrade in springs. I got to check that, thanks guys. |
