will a 20b tt work with stock 6 speed trans?
Old Sep 8, 2009 | 06:15 PM
mikebruzda's Avatar
CO will a 20b tt work with stock 6 speed trans?
im looking to buy a 20b tt, and nobody seems to be able to answer if a stock 6 speed trans with work with it, if anyone has any info please share, thanks
Old Sep 8, 2009 | 08:32 PM
kersh4w's Avatar
Hit & Run Magnet
it will work.
just be gentle.
really gentle.
Old Sep 8, 2009 | 08:37 PM
Rote8's Avatar
Use a transmission blanket.
I am not joking at all.
We need you to retain all your body parts.
Old Sep 9, 2009 | 07:01 AM
I just blew up my 4th stock trans behind a stock NA Renesis
If you don't mind shifting like a little girl then go for it, otherwise you better use a Tremec etc
the chain is only as strong as it weakest link and the RX-8 transmission is a very weak link.
Old Sep 9, 2009 | 07:44 AM
dznutzuk's Avatar
Uncontrollable drifter
I'd say use a rx7 fd, nothing else. Even angeljoev is hearing weird noises from his t56-not made for high revs
Old Sep 9, 2009 | 08:06 AM
dang, another one ?
wow ...
too bad you cant use 09+ tranny for your race.
Old Sep 9, 2009 | 10:57 AM
Yeah see the SCCA Nationals thread in the Competition forum.
A friend who runs a 20BT in an FD3 just switched to a Jerico dog box after blowing up multiple FD3 5 speed boxes, this is a clutchless shifting manual racing trans for a competition car but it makes the point that unless you don't mind breaking/replacing OE gearboxes you better get a stronger one that can handle the load
If you can't afford the rest of the equipment to support the engine then you can't afford the swap from the get go
you have to specify it's for a rotary, they make alternate parts for high rpm rotary engines, call Taylor etc
Old Sep 10, 2009 | 08:54 PM
chickenwafer's Avatar
Nope
Listen to Team, I just blew up an RX-8 gearbox with my "measly" (Compared to a 20B) 330-rwhp so yeah, do a Tremec T-56. See angeljoelv, he's done a REAL nice 20B swap with this trans
Old Sep 11, 2009 | 04:56 AM
wow,
anyone need a tranny. have one.
Old Sep 11, 2009 | 10:42 AM
stinksause's Avatar
The Stink w.o The Sause
so what would you say is the highest reliable power for the stock 6 speed?
below 320 whp?
Old Sep 12, 2009 | 08:50 AM
Bulletproof reliable = 100 rwhp
Old Sep 12, 2009 | 05:53 PM
arghx7's Avatar
The turbo Rx-7 trannies are plenty strong unless you are doing hardcore drag racing all the time on them with very high horsepower cars. The 2nd and 5th gear synchros do wear out, but any shop that has rebuilt Ford Ranger manual trannies can rebuild an Rx-7 tranny. I have zero tranny problems with 400+rwhp. I'd say they are good to 500+rwhp depending on how much drag racing you do. If you don't launch them you won't break anything for a long time.
For the 20B you will need the proper counterweight etc. along with solving the mounting issues. The 20B only came with an automatic from the factory.
Old Sep 12, 2009 | 07:24 PM
Sure, but in an SE3P chassis along with removing the center console, cutting a new hole in the tunnel for the shifter, and modifying the PPF to account for the longer tailshaft housing
I broke one of those in a stock FD3 too
not to mention that a 20B makes more torque at the likely shift point, which is what typically breaks them rather than peak hp
Old Sep 12, 2009 | 08:11 PM
@!!narotordo's Avatar
FLAME ON!
Get a $10k HKS dog gear tranny it will never die. Mazda has used the same bolt pattern sence 79 I think? I could be wrong. Might be more back than that.
Old Sep 14, 2009 | 09:31 PM
the question is whether or not they make the tailshaft housing length and hence shifter and PPF mounting locations for an RX-8 chassis
There are likely less costly options using modified T5, T56, etc. transmissions
Old Sep 22, 2009 | 12:39 AM
not sure if I'm clear to be posting this publicly, but Doug @ Taylor Race Engineerng sent me a pic of this Quaife sequential setup that was recently installed in an RX-8
Attached Thumbnails will a 20b tt work with stock 6 speed trans?-rx-860gbolt-up.jpg
Old Oct 5, 2009 | 03:55 PM
I've asked PAR-Engineering to confirm whether or not the gearsets they sell for the Miata 6 spd Aisin AZ6 transmission will fit the RX-8 6 spd Aisin AZ6 transmission, they offer both straight or helical, dog or synchro, no extra charge for custom ratios
http://par-engineering.com/sections/...da&sectionId=6
http://par-engineering.com/sections/...da&sectionId=7
Old Oct 5, 2009 | 04:36 PM
Rotr8's Avatar
whines all the way home
wow, pretty sweet Team,,, keep us up to date with anything TRA shares with you as long as your allowed to,,,
Old Oct 5, 2009 | 05:31 PM
Nope
Sweet thanks for updates Team, this is very helpful...
Wonder how much that Qualifie sequential is, LOL
Old Oct 5, 2009 | 09:18 PM
kersh4w's Avatar
Hit & Run Magnet
yeah i would like to know too.
Old Oct 5, 2009 | 09:34 PM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
That thing looks beefy
Old Oct 6, 2009 | 01:38 AM
I didn't ask about the Quaife, but north of $10,000 wouldn't surprise me, a sequential isn't legal in some classes ....
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Billy Marcial
Mar 1, 2018 06:50 AM
cschoeps
Aug 6, 2015 12:44 PM
Nisaja
Aug 6, 2015 01:27 AM
