Formula to convert Stock Wideband O2 reading to AFR???
Old Sep 8, 2009 | 01:14 AM
rx8dorifto's Avatar
anyone can enlighten me the formula to convert the stock Wideband O2 reading (in mA) to AFR reading?
thanks in advance
Old Sep 8, 2009 | 01:50 AM
MazdaManiac's Avatar
Nope. Can't do it.
You would need a driver circuit to convert it to volts, which would interfere with the PCM's circuit.
Old Sep 8, 2009 | 03:36 AM
rx8dorifto's Avatar
Originally Posted by MazdaManiac
Nope. Can't do it.
not possible?
How are those OBD scan tools do it? e.g. Canscan, OBDScan, Cobb AP, EFIDude, etc?
My OBDKey give me these data:
O2 Sens1, B1(WR)***mA Eq. ratio
0.406**************1.179
-0.762**************0.846
-0.387**************0.914
1.727**************1.379
Wondering how to convert them into useful AFR.
Old Sep 8, 2009 | 06:52 AM
Spin9k's Avatar
Momentum Keeps Me Going
Of course it's possible. MM is assuming you want to create some additional gauge to hook in, where what I see you asking is "How is the current reading converted to an AFR?"
There's a graph that shows the conversion somewhere, it's also in the shop manual I think, I may have it too if I can locate it, but it's here on the forum somewhere, just hard to find in here with the millions of tidbits of stuff in here.
Old Sep 8, 2009 | 06:58 AM
mysql101's Avatar
EQ Ratio to AFR: AFR=Stoichiometric/EQ Ratio
Old Sep 8, 2009 | 07:36 AM
Spin9k's Avatar
This doesn't help him. The O2 produces a current that is converted into a lambda value in the ECU. The sensor doesn't produce a std voltage output. He needs the current > lambda conversion 1st.
Old Sep 8, 2009 | 08:31 AM
rx8dorifto's Avatar
thanks mysql101, you mean I should divide my "mA Eq. Ratio" to the Stoichiometric (14.7) like this:
mA Eq. ratio
14.7 / 1.179 = 12.468
14.7 / 0.846 = 17.376
14.7 / 0.914 = 16.083
14.7 / 1.379 = 10.660
Does this looks right?
Old Sep 8, 2009 | 08:42 AM
rx8dorifto's Avatar
i think mysql101 is right, found this on other website:
To convert EQ Ratio to AFR, use: AFR = {stoich}/EQ
To convert Lambda to AFR, use: AFR = Labmda/{stoich}
To convert AFR to EQ Ratio, use: EQ Ratio = {stoich}/AFR
To convert Lambda to EQ Ratio, use: EQ Ratio = 1/Lambda
To convert EQ Ratio to Lambda, use: Lambda = 1/EQ Ratio
Old Sep 8, 2009 | 10:55 AM
That isn't what you asked.
Old Sep 8, 2009 | 11:09 AM
If we are going to play semantics with the guy, MM, then the only correct answer to his question would have been "no".
Nope. Can't do it.
I thought I was pretty clear.
He asked for a "formula" that converts the mA (that means current) output of the sensor to AFR. That means a wire to a meter to a formula.
Not for a formula to convert the calculated output of the sensor (as performed by the PCM) to AFR.
Old Sep 8, 2009 | 11:24 AM
Re-*******-lax.
Answering forum posts on my phone by the pool sipping coffee.
Old Sep 8, 2009 | 12:16 PM
Spin9k's Avatar
I swear you guys are like a bunch of old ladies . All the guy wanted was the formula - you all go into some semantics argument and never get to it....remind me of my wife lol!
anyway... perhaps the forumla can be derived from the following:
Old Sep 8, 2009 | 08:16 PM
rx8dorifto's Avatar
thanks a lot guys.
my bad, was confused by the term "mA Eq. Ratio" which provided by OBDKey. After much searching, i've got it now.
Old Sep 8, 2009 | 08:47 PM
KRMRX8's Avatar
Is there any reason why the FJO WB AFR unit could not be spliced into the OEM WB sensor wiring to connect to their gauge without it disrupting the ECU , err_ PCM signal?
Old Sep 9, 2009 | 06:22 AM
rx8dorifto's Avatar
Not sure the correct Stoich is 14.7 or 14.63 which i saw somewhere else.
I just did a logging apply this Stoich/EQ Ratio with 14.1 stoich as i'm running RON97 and here is what I got for my AFR. It doesn't look right though...compare to what I've seen here on this website.
Attached Thumbnails Formula to convert Stock Wideband O2 reading to AFR???-afr_14.1stoich.jpg
Old Jul 6, 2010 | 07:46 AM
RIWWP's Avatar
Nevermind. Wrong sensor
Old Jul 18, 2010 | 02:07 PM
Q-ball's Avatar
Question.. my stock o2 sensor was cut (while my exhuast was stolen) wanting to know solution eg. can i simply run a wide band o2 sensor to stock ecm and to a a/f guage or no. sorry if its a noob question.. thanks!
JimmyBlack
273
Feb 10, 2020 10:23 PM
OnebaddRx8
Aug 25, 2019 11:34 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
XianUnix
Sep 29, 2015 03:48 PM
