Nitrous Kits
Old Sep 5, 2009 | 07:20 PM
Shane82's Avatar
Nitrous Kits
I know alot of people are using zex on the 8's for the FMU, but has anyone used regular wet nos or nitrous works kits without any problem. Also would I need to go to a colder plug with just a 50 - 55 shot?
Old Sep 5, 2009 | 08:03 PM
nuke0907's Avatar
Never Blend In
Zex is just a name on the bottle. all the kits are basically the same.
Old Sep 5, 2009 | 09:08 PM
Easy_E1's Avatar
75 shot ZEX kit here.
Old Sep 5, 2009 | 09:13 PM
Shane82's Avatar
I've used nitrous express on other cars so I will probably go with that, its just more wiring than a zex kit and I would have to use a window or a push button switch. Are the stock plugs good to go with a 50-55 shot or should I go colder?
Old Sep 5, 2009 | 09:29 PM
Phish806's Avatar
window switches do not work with the 8. the zex kit is jsut hte more simple way to go.. However the other kits would work just alot less fool proof.
Old Sep 5, 2009 | 09:32 PM
Shane82's Avatar
I'll probably just use the push button activation and of course only use it above 3k rpm. Anybody have any suggestions on plugs for a 50-55 shot?
Old Sep 5, 2009 | 10:20 PM
Easy_E1's Avatar
ZEX,, Plug and play.
I use stock plugs and an Accessport for tuning. Don't do the 75 with out tuning.
Old Sep 5, 2009 | 10:26 PM
Shane82's Avatar
I'm going to keep it at a 55 shot just so I don't have to worry about tuning and changing the plugs.
Old Sep 6, 2009 | 03:07 AM
bse50's Avatar
#50
The Zex kit is going to be the easiest one to install. There should be a couple of build threads where Charles R. Hill took pictures. He also sells a spacer for the nitrous nozzles so he would be the one-stop source for both the infos and the parts you need
Old Sep 6, 2009 | 05:17 AM
Rote8's Avatar
Is anyone boosted and running nitrous?
That might break 400RWHP easily, or break apexes trying.....
Also, why not direct port injection for the nitrous, instead of running it through the intake, tap two nozzle holes on the lower intake, near or almost in the engine intake ports.
Then use two nozzles instead of a single nozzles and the nitrous would not run through the upper intake at all.
Old Sep 6, 2009 | 05:31 AM
bse50's Avatar
#50
The problem is: how would the nitrous mix with the a\f mixture in such a short distance? Also tuning for it would be a bit more problematic imho
Better use those nozzle for a water\meth system at this point!
Old Sep 6, 2009 | 01:21 PM
Shane82's Avatar
will a nitrous express nozzle work with the BHR spacer?
Old Sep 6, 2009 | 08:53 PM
Shane82's Avatar
Does an RX8 hit wide open throttle at 3k rpm like most other cars do?
Old Sep 6, 2009 | 09:26 PM
Shane82's Avatar
What I meant was would you engage it at 3k rpm like you would in a piston engine.
Old Sep 6, 2009 | 09:35 PM
Shane82's Avatar
Ok so to be safe don't activate the nitrous till about 4.5k
Old Sep 6, 2009 | 10:30 PM
Mr.We$t's Avatar
Rx-8 the protege
Were can I purchase a brand new nitrous kit? I've been searching all day and can't seem to find it! It's probly just me and my searching skills but if u canpoint me in the right direction I would greatly appreciate it!
Old Sep 6, 2009 | 10:35 PM
05rex8's Avatar
sold the 8... :(
http://www.fluidmotorsports.com/p-15...n-nitrous.aspx
Old Sep 6, 2009 | 10:53 PM
hakuna matata!
Check my sig for my install.
Listen to everything Charles has to offer.
Mr.We$t's Avatar
Rx-8 the protege
Thanx mang I got lots of reading to do!!
Old Sep 6, 2009 | 11:02 PM
getdamafiaonyou's Avatar
Charles R. Hill. Best place to buy the zex kit. Get the blackout, it is sexy as hell.
Old Sep 6, 2009 | 11:24 PM
Mr.We$t's Avatar
Rx-8 the protege
hay alzorz I was reading through thread first I wanna say mad props! I noticed u mounted one of the parts from the kit onto the stock airbox! I have a typhoon 2 intake will that be a problem with this kit
Old Sep 7, 2009 | 02:20 PM
jeffRX's Avatar
Black on black on black..
I have the Typhoon 2 aswell and mounted the zex module on the back of the heat shield. drilled the hole into the intake tube and works perfect.
Old Sep 8, 2009 | 04:27 PM
Shane82's Avatar
Just picked me up a used zex kit for $300 can't beat that
Old Sep 8, 2009 | 05:15 PM
Mr.We$t's Avatar
Rx-8 the protege
Great man keep us posted on your install, I think I'm going to do this nitrous thing.
Old Sep 15, 2009 | 02:27 AM
toneskii707's Avatar
suck my smog
I did the same thing on my k&n V2 some black tape and black wire loom and the CHPs will never find it, I have the TB spacer and stealth nozzle so its super stealth!
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Digitz0070
Sep 27, 2015 07:49 AM
Digitz0070
Sep 25, 2015 10:58 PM
