Subwoofer OHM question
Old Aug 21, 2009 | 06:26 PM
CompMan's Avatar
iDüber
Let's just start by saying Ohms confuse the hell out of me!!
I have a Alpine PDX-1.1000 amplifier that I want to run at 4 ohms. I'm planning to buy 2 Alpine Type R 10" subs.
They come in 2 versions, one says 2ohm + 2ohm and one says 4ohm+4ohm. Now which one do I buy to run at 4ohm? With two of them in parallel.
Old Aug 21, 2009 | 06:32 PM
Hoss's Avatar
The dual 4 ohm flavor.
Wire each sub in parallel, and then tie the subs together in series.
Old Aug 22, 2009 | 11:03 AM
nuke0907's Avatar
Never Blend In
first off, you cant set your amp to run at a certain resistance. it is dependent on your load(the subs).
here's a link to some very good info to help you out.
http://www.crutchfield.com/learn/lea...amp_guide.html
Old Aug 22, 2009 | 11:40 AM
Charles R. Hill's Avatar
Owner of BHR
Although some amps have selectable load, this Alpine does not. However, it will drive either 2 Ohm or 4 Ohm loads, according to Alpine.
http://www.alpine-usa.com/US-en/prod...del=PDX-1.1000
Hoss has the right idea as for wiring but I wonder why you want to use dual-coil subs only to play around with series/parallel wiring?
Old Aug 22, 2009 | 03:28 PM
cornholio135's Avatar
SARX
I found this and it was very interesting on the advantage of dual voice coils...
seems more for flexibility than anything...
http://mobile.jlaudio.com/support_pages.php?page_id=163
Old Aug 22, 2009 | 04:02 PM
Hoss's Avatar
The subs he wants to use are only offered in the dual coil configuration.
The ONLY advantage multiple coil subs have is flexibility. I have worked with a lot of speaker design, and there is nothing else to gain from using more than one coil other than multiple wiring options. Most manufacturers aim to provide woofers that mate with their amps to work at an ideal impedance load.
Old Aug 23, 2009 | 07:52 AM
firebirdude's Avatar
User and Abuser
The only thing I could possibly see as an advantage to DVC subs versus SVC subs would be power compression. Dumping 2kWRMS on one coil versus 1kWRMS on two coils. Never really comes into play for the masses though.
Old Aug 23, 2009 | 09:50 AM
Hoss's Avatar
That isnt exactly how it works though, unfortunatly...
You are still putting 2kw into the same space, through most likely the same length of wire, and would still generate the same amount of heat...
Old Aug 23, 2009 | 11:13 AM
User and Abuser
although I'm sure that's true, I just figured it'd be one less place for heat to build up.
Old Aug 23, 2009 | 01:38 PM
CompMan's Avatar
iDüber
So hoss has the answer?
Thank you very much, this stuff get confusing lol
Old Aug 23, 2009 | 02:04 PM
User and Abuser
Yup. Dual 4 ohm and wire them just as Hoss said.
Old Aug 23, 2009 | 02:35 PM
Hoss's Avatar
Hoss has all the answers... lol :p
Evan Gray
Nov 24, 2015 01:00 AM
urbanvoodoo
Sep 30, 2015 12:41 AM
pjwermuth
Sep 28, 2015 11:36 PM
kody59
Sep 28, 2015 03:43 PM
Learners_Permit
Sep 27, 2015 07:38 PM
