View Full Version : Quick Performance Packages
JGable
08-13-2009, 08:35 AM
So I'm very new to this RX8 forum and RX8 ownership... that being said I'm already looking for more performance out of the 8. I've been reviewing this forum and have found an abundance of information and advice (so much my wife is starting to check out clinics for addiction) I ran across this website and I'm considering it heavily but I need good sound advice with unbiased opinions from people that frankly know a bunch more than myself. Looking forward to seeing your postings and suggestions, thank you all for your help and advice!
http://www.srmotorsports.com/RX8_Packages.html
DarthRX8
08-13-2009, 08:58 AM
buying one of these performance packages IMO would be a bad idea (companies like to inflate their dyno numbers in order to sell their products... imagine that :) ). Depending on how much money you want to spend and what you want out of your 8 determines a lot.
If you are going to stay NA and want to get the most hp out of your 8 the best way to do that is:
1. Drop in K&N filter - $40
2. mid pipe (Racing Beat, BHR, TurboXS)/ High flow cat (RP Supercat) - anywhere from $250 to $400
3. Accessport (to tune it) - $730. If you buy from MAzdamaniac the tuning comes free with your purchase.
Total = $1170 and you will get more from this than any set up from that website.
It all depends on what you want to do to your 8. Yes some products are better than others and the best way to find them is to SEARCH this forum! If you want to compare sounds of different products (exhaust, intake, midpipes) go to you tube, there are tons of them!
You have a lot more searching to do, so get to it!
Huey52
08-13-2009, 09:03 AM
Note: A 'midpipe' in this context replaces the catalytic converter and is only intended for track use.
JGable
08-13-2009, 09:13 AM
Okay, thanks guys, I haven't heard much about the accessport stuff, I'll check those out. Again, thanks!
DarthRX8
08-13-2009, 09:21 AM
***edit*** If you want to stay emissions legal then a High flow cat would be what you want (not a mid pipe). Gains are not as significant though...
Charles R. Hill
08-13-2009, 09:30 AM
What are your short and long-term goals for your car?
There are some mods that are a slam-dunk benefit, even if you otherwise stay stock or N/A, there are some mods that are simply a "style" decision, and there are mods that are a plain waste of money.
JGable
08-13-2009, 09:41 AM
Short Term goals are to just increase acceleration a bit, and make it sound a bit better. But really, I love just driving my car and want it running at it's best performance possible but not with crazy modifications (if that makes any sense). I want a smooth running car that I can have fun around the corners and going on the highway with.
Long Term is to take it to a drag strip and have everyone in aw that a Mazda with a 1.3L just kicked the crap out of the tubbed Mustang. But then again the later may be a dream instead of a goal lol.
bse50
08-13-2009, 09:47 AM
I would also point out that some mods may fit better some circumstances than others. Think about ring and pinions, clutches etc. They are a waste of money for some uses but may be useful for others.
Thinking about the engine, and not about other drivetrain parts i think that a good starting point to see some benefits might be a midpipe\sports catalyzer (depending on your emission laws etc.. i personally don't care :) ), airbox baffles removal, upgraded coils and accessport.
Depending on your mileage then you might want to look at your fuel pump's sock or entire fuel pump assembly but there we are more into the maintenance needs of a car. If your car is poorly serviced even thoroughly cleaning your maf\iat setup and throttle body might help!
It's good to see a new member politely asking something, welcome on board!
JGable
08-13-2009, 09:55 AM
Wow, bunch easier on me (and my wallet) than I thought, and the more I look at that Accessport, the more it's a sure thing or a "must have' of sorts. Going to go searching for a knowledgable shop in Richmond now to see if they'll do a run over on my car to show me what I need to start thinking about because as we all know text can only get you so far before I actually need to get off of my ass and into a shop. I'm still waiting for a reply that says something like "You need to search the boards instead of clogging up the site" so if someone would reply with something like that it'd be much appreciated. I don't want to feel left out.
bhop
08-13-2009, 09:56 AM
Save up a couple grand first unless you already have the funds. Anyway, get a midpipe, I could care less if it was intended for track use only considering plenty of people have it anyway. A-Port from Mazda Maniac, Racing beat or Progressive front/rear sways, coilovers(what ever floats your boat, tein, kw variant, BC racing, JIC, etc. Upgrade tires and get lighter wheels. Don't forget BHR products, I would get their ignition kit. Cold air intake if you must. You don't need to over do it with the exhaust. If you are running low on cash then wait and save. Start with midpipe, MM A-port but even that alone is $730 but still great to have. If not, Get the midpipe(Racing Beat for me), F/R sways, BHR igntion, lowering springs(these are not really needed. So as you can see there are various ways to go about this situation. Personally I would save up some more so you are not wasting money because you want something right away. The site is to assist you and I'm sure the ideas on here are enough to do your own build LOL.
One more thing, what are you planning on doing with the car unless it's just a daily driver for now. Some people can be assholes and some people are just being funny and joking around because everyone else is doing it. Don't worry about people telling you to go search, I mean its not that hard to search, lol.
Good Luck
-Brandon
Charles R. Hill
08-13-2009, 10:09 AM
Your ST goals are what we all want. ;)
Your LT goals are definitely a stretch but at least you are being realistic about it. Save your money up for a 20B swap and, when you are ready, we have some guys in Puerto Rico we can introduce you to. :)
For the first step into modding the RX-8, I think the general consensus has been to suggest the first mod be driver-related....... as much track time as you can afford. This is because the RX-8 has performance subleties to it that are only realized when you toss the car into a corner at 7,000 RPMs. To sum it up, the RX-8 is far more capable than 99% of those who own it, myself included.
The next key is to understand where it is that Mazda absolutely NAILED the car's performance. For example, I tend to tell people to stay away from dramatic braking and suspension mods (at least in the beginning) because it is quite easy to make matters worse with too much complexity. After that, you will just be frustrated.
On the other hand, there are mods that seem to be universally-satisfying. Such as;
1) Cobb AccessPort, Hymee Pro-Tuner, Racing Beat re-flash, and other types of re-flash tools.
2) BHR Ignition System, Esmeril Racing Ignition Kit, Okada Products Coils, and so on.
3) Catless midpipes from Racing Beat, BHR, and others.
4) Lightweight flywheels from ACT, Fidanza, BHR, and many others.
5) Cat-back exhaust systems, though they are largely for style and sound.
6) Racing Beat or AEM intake system even though intakes don't tend to improve on the mass-airflow entering the engine (none that has been documented and presented, anyway).
7) Swaybars from Progress Tech, Racing Beat, and many, many others as well.
8) Suspension springs. Too many to list but Progress Tech and Racing Beat are good choices.
9) Dampers (once your OEM units are shot) from Tokico or Koni, although I prefer the easy adjustability of the Tokico D-Specs.
10) Brake pads if you plan on tracking the car. Nothing too aggressive is needed and the Hawk HPS is a popular choice around here.
11) Better tires can be installed, depending on your particular preference. 245/40-18s are a favorite as they fit on the factory wheels.
Once you have addressed these areas we then have less-effective stuff we can discuss.
adamwzl
08-13-2009, 10:12 AM
Nvm
04RX8man
08-13-2009, 06:46 PM
Just go big or go home...20B haha....
pdxhak
08-13-2009, 06:55 PM
BHR should put together a "performance package" for around $1k :)
JGable
08-13-2009, 07:12 PM
I think that's a wonderful idea PDX, who do we need to talk to for that? I mean, anyone could sucker me in if all they did was bundled it. They could even overcharge me for it, it's just convienient... I mean, I'd need a discount for it...
04RX8man
08-14-2009, 11:35 PM
well we'll have to talk to Charles.......any packages comeing out? I'd be happy with the Midpipe, coils, and some suprise mod for 1k!!!!
shazy
08-22-2009, 08:15 PM
That would be interesting :)
pdxhak
08-22-2009, 08:54 PM
I'm thinking since he has not replied he is not feeling the idea.
