Toyo R1R vs Bridgestone RE-11?
Old Aug 10, 2009 | 10:58 PM
Butters's Avatar
newbtacular newbness
Hey guys, I'm looking to get replacement tires for the stockers soon and I've been going back and forth between the Toyo R1R or the Bridgestone Potenza RE-11 tires. I am doing mainly spirited daily driving/canyon runs and an occassional trackday every now and again. I live in Seattle so moderate to sometimes heavy rain will be a consideration, but I do take public transit a lot, leaving the 8 and my Ducati in the garage for dry days; I just want the wet performance for if I do decide to take the 8 out in the rain.
Given these parameters, which would you recommend? One last consideration is that I am not a high mileage kind of driver so tread wear, while still a consideration, takes a backseat to performance. I tried searching, but didn't come across much in the way of RE-11 opinions/reviews. Thanks in advance for any and all feedback!
Old Aug 11, 2009 | 01:19 AM
TopGear8's Avatar
mkuhnracing.com
Don't get the RE-11 unless you AutoX and can compete for contingency money. They are just too pricy. The new Kumho XS is a great canyon run/track day tire that has similar dry grip to the R1R and the RE-11.
Although if your looking for a good rain tire as well, the XS is not for you. The R1R is much better in the rain then the others listed.
Also check out the Dunlop Direzza Sport Z1 Star Specs.
Old Aug 11, 2009 | 01:56 AM
My FC buddy has almost 4K miles on his set of XS and is an avid autox/canyon carver. Halfway through tread with minor camber wear. ~9K miles for a REALLY GOOD set of tires is very good
Old Aug 11, 2009 | 02:11 AM
RickA's Avatar
Party.
FYI i have R1R's in 265/35 and I can still break them loose
Old Aug 11, 2009 | 02:29 AM
Butters's Avatar
So is that a knock against their dry grip?
Old Aug 11, 2009 | 02:37 AM
RickA's Avatar
Party.
I'm not knocking anything, just giving you a heads up... I haven't used any other tire on the 8 yet so I can't offer any comparative information/advice
Old Aug 11, 2009 | 02:52 AM
Butters's Avatar
I appreciate the heads up, just trying to clarify if what you are saying is that the dry grip is lacking in your opinion. And if so, could you elaborate a bit? (i.e. What are you doing to break them loose? Under what conditions, etc.)
Old Aug 11, 2009 | 08:23 AM
BRODA's Avatar
Not yet famous
I have 265/35/18 Toyo R1R's also. If you are breaking them loose on the street, you are driving very recklessly.
Nonsense aside, I would probably suggest the Dunlop Direzza Sport Z1 Star Specs over the other tires listed above for daily driving. If you don't mind sacrificing a bit of ultimate grip for better street manners and longer tread life, I run T1R's on the street and they have more grip then I would ever use on a public road.
Old Aug 11, 2009 | 08:27 AM
Huey52's Avatar
Registered Zoom Zoomer
Toyo T1R. Excellent for spirited street and occasional track days. They're very good in the rain for your locale as well.
Old Aug 11, 2009 | 09:12 AM
ChrisRX8PR's Avatar
13B-RE
TOYO T1R's all the way.
They handle 500whp+ from my engine without issues, they last longer than most sticky tires and they handle the turns great. I used to brake loose from a roll in 3rd ans sometimes even in 4th and now it only does it in second and the rest of the time it lays it down. I could not be happier...
I do use 275-35-19 though which is taller than most will use but this is due to my power band which is a little abrupt.
Chris
Old Aug 11, 2009 | 09:21 AM
RickA's Avatar
Party.
story of my life
Old Aug 11, 2009 | 09:29 AM
RickA's Avatar
Party.
accelerating from 30-70 on a 40mph sharp radius on-ramp
making a 90* turn in an intersection from a dead stop with ~50%-75% throttle
Old Aug 11, 2009 | 11:06 AM
Butters's Avatar
Chris
Hmm. Can't really argue that much with someone who is putting 500 whp through the tires. Thanks for the input.
Old Aug 11, 2009 | 12:02 PM
TopGear8's Avatar
mkuhnracing.com
^Yeah except breaking loose from a straight line roll is much different from the rear end comming out around a corner...
Old Aug 11, 2009 | 12:04 PM
Butters's Avatar
Agreed. I still appreciate all the input from all parties regarding all aspects of the tires in question.
Old Aug 11, 2009 | 01:38 PM
RawrX8's Avatar
Grocery Getter
Ill be picking up some Dunlop Direzza Sport Z1 Star Specs myself after seeing some local guys autox on them all year and still have lots of tread left.
If you quit being a cave monster come out to some of the Seattle things we do there is lots of information/experience from us.
Old Aug 11, 2009 | 01:43 PM
Butters's Avatar
Hahaha, fair enough. PM when the next meet is happening. BTW, diggin' your car in your sig, wanna check it out in person.
Old Aug 11, 2009 | 02:01 PM
LionZoo's Avatar
road warrior
The R1R is going to have more dry grip than a T1R. Same thing with the RE-11. The T1R isn't the same class of tire.
Old Aug 11, 2009 | 06:24 PM
Huey52's Avatar
You're right, the R1R is an Extreme Performance Summer tire, which is way overkill given the OP's original insight, hence the T1R recommendations.
Old Aug 11, 2009 | 06:30 PM
LionZoo's Avatar
road warrior
Considering he runs canyons and trackdays, what exactly about the R1R is overkill? Seems like the Extreme Performance category is perfectly suited for his needs.
Now there is talk about the R1R having heat issues, and that might manifest itself on a track day, so I'd go with the RE-11. However, the T1R will overheat just as fast if not faster than the R1R.
Old Aug 11, 2009 | 07:05 PM
BRODA's Avatar
Not yet famous
Are you sure?
Old Aug 11, 2009 | 08:05 PM
LionZoo's Avatar
road warrior
Are you sure?
No I'm not sure, I'm just making a judgment based on tire performance rating. I'm willing to bet the RE-11 is more temperature stable than the T1R though, just an informed guess.
Old Aug 11, 2009 | 09:18 PM
GeorgeH's Avatar
I've been autocrossing R1-Rs for most of the season, and they are a great tire. However, from a performance standpoint, the RE-11, XS, AD08 are all equal or slightly (to the point it does not matter for non-competitive driving) better. At least in the dry. XS is out for you because of wet performance, as others have said.
The R1-Rs do have a reputation of overheating. This does not surprise me as sometimes my quickest run is my first, and I did overheat them the other day with 8 back-to-back runs in 90 minutes. At an autocross I can spray between runs to manage the tire temp, but you can't do that during a 20 minute track session.
I also had T1-Rs, and they are great on the street - a very fun tire, from a subjective standpoint, but lower in grip, and I don't think they would be a stellar track tire.
For combined street driving & track days, I'd look at the Bridgestone or Yoko AD08. Or, perhaps the Toyo RA-1 if you want a serious track-day tire that is steetable (but it will wear faster than any of the above). But it sounds like that might be overkill for you.
Old Aug 11, 2009 | 10:09 PM
Butters's Avatar
^^Cool. Thanks for all the insight!
Yeah, it looks like I should really be leaning towards the Toyo R1-R's. Or perhaps, even the T1-R's if I'm not going to be concentrating on trackdays and mostly canyon runs with the occasional trackday (I'm not a complete track junkie. Beginner's group fo' sho')?
Old Aug 11, 2009 | 11:22 PM
Nopstnz8's Avatar
Get the RE-11's FTW! These are the replacement to the RE01-R's which I currently have on my DD and they are amazing. Even in the rain, you don't have to worry about losing traction. They were better in the rain than my old all-season tires. Seriously though, I attended an autocross with these and they performed very well through 8 laps. A ton on Auto-X drivers use these, as well as the RE-11's. Bridgestone FTW! End of discussion! You won't be disappointed with RE-11's, I guarantee it.
