Intake screen question
Old Aug 5, 2009 | 01:50 AM
much2saxy's Avatar
I read up on all the jazz about removing the intake baffles and screens and played around with it today. I had to leave one screen in because of a very rough idle, but no big deal.
What I found interesting is that when I removed the first screen (inside the horn) I found a dusting of what appeared to be a black dirt. At first I thought the K&N filter wasn't oiled properly or something and planned on cleaning and re-oiling it after I was finished. But, when I pulled off the second screen (one closest to the MAF) I distinctly noticed that the "dirt" was on the engine side of the screen, and not the fresh air side.
Since the "dirt" was black I figure it might be carbon, but that far up in the intake? Any ideas on what this is?
Old Aug 5, 2009 | 02:44 AM
Jon316G's Avatar
Grasshopper
Sounds like a little bit of oil (or oil vapor) collected there.
You probably have an '04 or '05?
In those models there is a breather hose for the oil filler neck that connects to the intake.
Might want to give the MAF a generous spray with contact cleaner to ensure the resistor wires are clean.
Old Aug 5, 2009 | 03:33 AM
2SeeKU's Avatar
Aussie
He has an 09.
My throttle body was alittle oily, could just be from the same place..
Old Aug 5, 2009 | 03:36 AM
Spinning Sushi's Avatar
I <3 Sushi
It's possible that dirt got through the filter. Maybe there's a very small turbulence vacuum behind the lining of the screens so dirt collects there. It's similar to the turbulence and vacuum created by the rear of a truck when they're doing 55 mph.
Old Aug 5, 2009 | 03:37 AM
Jon316G's Avatar
Grasshopper
Originally Posted by 2SeeKU
He has an 09.
OOPS... just saw that in his signature. Nevermind!
Old Aug 5, 2009 | 08:53 PM
much2saxy's Avatar
Just to be sure I cleaned and re-oiled my filter.
gwailo
May 14, 2024 06:57 AM
FirstTimeRX8Girl
Aug 21, 2015 06:51 PM
tgaffner
Aug 20, 2015 10:55 AM
poppinparker
Aug 10, 2015 09:20 AM
TheWhiteAce
Series I Engine Tuning Forum
Aug 6, 2015 02:26 PM
