Noise when clutch is pushed, from outside car (not braket!)
Old Aug 1, 2009 | 04:32 PM
klittl06's Avatar
So, I'm driving home yesterday and when I push the clutch pedal I a creaking noise. It is not the pedal bracket, mine has been welded and the noise seems to be coming from outside the car.
Its sounds like it is coming from the pushrod on the top of the transmission. What do you think? Can I lube this?
Old Aug 1, 2009 | 04:37 PM
Jon316G's Avatar
Grasshopper
The rod that attaches to the release fork should have grease, couldn't hurt to re-grease it.
If its not that, it could be the release bearing.
Old Aug 1, 2009 | 05:21 PM
klittl06's Avatar
The noise sounds like a creaky old door if that helps. And it is only when pushing the pedal, not releasing.
Hopefully greasing will work...
Old Aug 1, 2009 | 05:22 PM
Jon316G's Avatar
Grasshopper
Right... but your release bearing is in use while you are pushing the pedal in.
Anyway, hope you figure it out.
Dokuji
Nov 1, 2016 02:51 PM
BigMikeATL
May 26, 2016 12:31 AM
Belalnabi
Jul 17, 2015 07:48 PM
LiftOff
Jul 16, 2015 08:24 PM
