Question about plug wires
Old Jul 31, 2009 | 09:37 PM
djp_rx8's Avatar
This might be a dumb question, but I just replaced my spark plug wires and I know the right plug is connected to the right coil but I didn't pay attention to the length of the wires and what length wire connected each plug and coil. Does it make a difference?
Old Jul 31, 2009 | 09:41 PM
Jon316G's Avatar
Grasshopper
As long as the wire has some slack, you'll be fine.
Normally, the longer wires go to the bottom plugs since they are father away.
Old Jul 31, 2009 | 10:45 PM
djp_rx8's Avatar
Ok. It seems like it is flatter at high rpm's and doesn't pull as hard but maybe I'm imagining it. Can't think of any reason why that would be the case, but it seems like it. Definitely runs better at idle and lower rpm's though.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
uZu
Dec 30, 2015 12:35 PM
Modern2Strokez
Aug 16, 2015 01:07 AM
