Switch blade key battery
Old Jul 31, 2009 | 12:32 PM
CompMan's Avatar
iDüber
WHere is it??! and how do you get it out to replace it?
I can't find it anywhere
Old Jul 31, 2009 | 05:56 PM
EDZRIDE's Avatar
2005 White GT
Try this
Attached Thumbnails Switch blade key battery-untitled1.jpg   Switch blade key battery-untitled2.jpg
Old Nov 23, 2012 | 04:00 PM
Frank Clark's Avatar
Smile Found the tiny slots~!
I sympathize with your frustration. I too had a very hard time finding the special "slots" to press with the mini-screwdriver. Once I found them, the top cover was very easy to remove.
Look closely at the very end of the key fob, after the switchkey part has been removed. You will see two tiny rectangles, about the size of the tip of your mini-screwdriver, and not deep at all.
At first these slots look unrelated to the top of the keyfob. It is these tiny slots that need to have the screwdriver inserted, and then twisted. The cover will then come off easily. A mini-screwdriver blade is needed, not just a small screwdriver.
Do not try twisting the larger holes. Your keyfob will break. Good luck!~
Old Nov 23, 2012 | 07:56 PM
Grace_Excel's Avatar
Charles Bundy
Nice, BUMPING a two and a half year old thread!
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Jst4fun
Mar 5, 2021 07:16 PM
Evan Gray
Sep 26, 2015 12:30 PM
