Transmission Oil for the 8 in Toronto
Old Jul 28, 2009 | 02:54 PM
sunsilver's Avatar
ON Transmission Oil for the 8 in Toronto
Hi Guys,
I did a transmission oil change about 10,000 k ago with Castrol 75w90 GL-5 as it was all i could find. I've noticed that its getting a little tough to get into gear sometimes and more scary than that it grinds every time i shift from 3rd to 4th at any RPM above 4500.
I'm hoping that using a RED LINE GL-4 Oil will help. Problem is I can't find it anywhere near me. (Oakville / Mississauga / Toronto)
Any Suggestions?
Thanks.
Old Jul 28, 2009 | 03:22 PM
Thief's Avatar
Reppin Lightning Yellow
I thought you weren't supposed to use GL5 grade oil in the tranny? o_O
Old Jul 28, 2009 | 04:11 PM
ZmFnZm's Avatar
check scarboro mazda
Old Jul 28, 2009 | 04:30 PM
01Racing's Avatar
A grind on shifting usually indicates that the syncro's are worn, and changing gear oil may lessen it to a degree but wont fix the problem. You can try going to Redline MTL which is a lighter oil but in the long run that wont fix it.
Old Jul 28, 2009 | 09:02 PM
eMpTy265's Avatar
+1 for Scarborough Mazda
They sell the MT-90 / MTL that you're looking for, 2 quarts should do it.
(1.75L, 1.85 US qt according to the manual I have)
Old Jul 29, 2009 | 12:57 PM
sunsilver's Avatar
Checking with a service manual it says GL-4 or GL-5 but I've read on the forums here that GL-5 isn't the greatest. I'll call up Scarborough Mazda soon.. Thanks
Old Aug 1, 2009 | 07:43 PM
climacus's Avatar
If your shift quality degrade suddenly, your clutch might not be engaging fully. This is usually caused by the clutch pedal bracket failing.
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
Cookingislife1226
Sep 5, 2015 03:38 PM
