any engine failures with Cobbs AP, and/or sohn adaptor?
Old Jul 23, 2009 | 12:02 PM
FazdaRX_8's Avatar
just wondering if these items will take care of the common engine failures, every time I read an "getting another engine" thread it seems they don't have either of the Cobbs ap and/or the sohn adaptor equipped...
Old Jul 23, 2009 | 12:38 PM
if you use anything "improperly", it will damage your engine.
applies to everything.
Old Jul 23, 2009 | 12:40 PM
shaunv74's Avatar
Power!!
They will definitely help if you have a tuner adjust the OMP flow. But I think pre-mix is really the only solution for 04-08's.
Old Jul 23, 2009 | 01:40 PM
FazdaRX_8's Avatar
I have read about prmix, but between your fuel pump filter and fuel filter, how much is really getting it?
I am just seeing if the cobbs from MM and the sohn adaptor are the saving grace for the rotory
Old Jul 23, 2009 | 02:19 PM
mysql101's Avatar
sohn adaptor will help, but the oil is sprayed towards the outer edge of the rotor, so the center area isn't getting lubrication. You can look at the rebuild link in my sig to see my engine internals - the rotors edges where the oil was sprayed on them was spotless, but not so much elsewhere.
i think most people who use sohn also premix. myself included.
the junk u're seeing came from gasoline. that filter cannot filter a "good" premix.
I dont have a problem with idemitu.
Old Jul 23, 2009 | 02:22 PM
I've never pre-mixed.
Old Jul 23, 2009 | 02:31 PM
^^thats why ur car hates you
Old Jul 23, 2009 | 02:34 PM
shaunv74's Avatar
Power!!
Time to start selling squares on dates when Jedi's motor will go.
Old Jul 23, 2009 | 05:11 PM
04RX8man's Avatar
Rotary Powered Countryboy
^haha......
the cobb can either help or save your motor....have an idiot try ot tune the pcm easily can ruin a motor and fast!....on the other had can increase the OMP rate but like said above the center of the apex seals don't get the lubrication they need....so many of us premix(including me) to help with that.....
but JEDI must not like his car so he doesn't
Old Jul 23, 2009 | 06:31 PM
The question is invalid unless it's a 2009 or new engine.
All years before that have had the incorrect programing from the factory for the OMP.
Therefore the damaged is done before installation of these aftermarket products.
Old Jul 23, 2009 | 09:47 PM
Burton's Avatar
Rotary Rambler
My engine is at 130000 miles... no misstype... no premix... Its all about changing the oil often enough and taking care of your car, and a little bit of luck...
Old Jul 24, 2009 | 02:25 PM
shaunv74's Avatar
Power!!
Nor have I and I am nearing 50K miles on my rebuilt engine with a Sohn and Cobb AP. 3x the OEM volume of oil injected and I use 2-stroke in the Sohn tank.
Yeah but we all know you hate your engine and want to see how far you can abuse it. -j/k
Old Jul 24, 2009 | 02:32 PM
On the original engine? sorry, gotta call bs.
Old Jul 24, 2009 | 03:19 PM
FazdaRX_8's Avatar
why bs. for him as long as it startes and gets him to and from his destinations, he may not notice low compression...
Old Jul 24, 2009 | 06:26 PM
04RX8man's Avatar
isn't there a guy arond the boards with over 168,000 on the original engine...now i'm not sure if he premixed but I believe that number was awhile ago so he must be getting close to 200k
Old Jul 24, 2009 | 06:29 PM
News Flash: our engines are NOT ticking time bombs!
130k isn't all that hard with proper maintenance.
Old Jul 24, 2009 | 06:32 PM
shaunv74's Avatar
Power!!
+1
Expo1 had 100K+ on his engine tracking it regularly and only rebuilt it due to an oil seal leak.
Old Jul 24, 2009 | 06:55 PM
Its not hard. but no premix ? I wouldnt ... blah.
are you sure your engine is still working within spec? Have u ever check the compression on it ?
Just because it start, it runs, it gets u from point A to point B. doesnt mean its within spec. ask me how I know.
Im not talking crap, its true.
Old Jul 24, 2009 | 06:56 PM
Its not hard. consider older NA rotary can go 250 K miles.
but without premix ? hmm. I dunno.
Old Sep 11, 2009 | 05:30 PM
If the motor doesn't go to at least 100k I will shoot someone, . I am running synthetic(3k OIC as usual), premixing, and just ordered the SOHN which I will run 2 stroke through.
Old Sep 11, 2009 | 06:48 PM
Brettus's Avatar
Boosted Kiwi
how much oil do you use per 1000 miles ?
Old Sep 13, 2009 | 02:32 PM
ASH8's Avatar
Super Moderator
Is that 11 ounces, or 11 drops per second, sorry Charles?
Old Sep 13, 2009 | 03:01 PM
mysql101's Avatar
11 metric drops, so that's like 4 quarts.
