Torque on flywheel bolts.
Old Jul 22, 2009 | 08:42 AM
zoom zoom rx8's Avatar
does anybody know what the torque is for the bolts that hold the flywheel on?
Old Jul 22, 2009 | 08:50 AM
carbonRX8's Avatar
U-Stink-But-I-♥-U
You mean that big honking 54mm nut? 290-361 ft lbs.
Old Jul 22, 2009 | 09:45 AM
No, i think its like 5 bolts. Ill double check when i get home. But im almost certain its five.
Old Jul 22, 2009 | 10:39 AM
staticlag's Avatar
The Professor
Bolt that holds the flywheel on is a single 54mm nut.
Unless you have an aftermarket flywheel and you are attaching it to a balancer. In which case there are 5.
I used loc-tite red and tightened them to 40 ft-lbs each.
Considering the clutch cover bolts are only supposed to be at 33ft-lbs I think.
Old Jul 22, 2009 | 11:55 AM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Yeah, the aftermarket flywheels have some number of bolts that make the counterweight and flywheel one unit. Those are likely spec'ed differently from different manufacturers, but are likely in the 40-55 ft-lbs range.
In anycase, the unit as a whole is still bound to the e-shaft by a big, honken' (54mm) nut that you should get to 300 ft lbs.
And I believe that the red loc-tite is recommended by mazda as well as the aftermarket flywheel makers. IIRC, there is a pic in the manual that tells you specifically where to place it on the threads. not too far in, not too far out. Not sure why.
Old Jul 22, 2009 | 12:50 PM
Oh. Ok i see what your taliking about now i think. thanks.
Old Jul 22, 2009 | 01:04 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
OnebaddRx8
Aug 25, 2019 11:34 PM
RXFEVER
Aug 29, 2018 10:14 AM
FubarI33t
Sep 28, 2015 08:45 PM
xAgyex
Sep 28, 2015 08:54 AM
Anthony Kevin
Sep 7, 2015 07:36 PM
