Wierd Central Locking Problem
Old Jul 20, 2009 | 03:09 AM
barry_swanne's Avatar
Hi,
Recently my central locking has started playing up. I cannot lock the car using the keyfob unless I open and close the door up to 10 times!
Sounds wierd but basically after a journey I switch off, get out of the car, close the door, press the lock button and nothing happens. So I open the door briefly, close it again and press the central locking button again. I have to repeat this process up 10 times in some cases until it locks. Very occasionally it will lock first time. I have no issue opening the car using the keyfob, just locking it.
I changed the battery when it started hapenning as I thought this was the most likely cause but it's made no difference.
Could it be a faulty keyfob or something more serious? I daren't take it to the dealer as it could be expensive!
Has anyone had a similar problem? Thanks
Old Jul 20, 2009 | 02:46 PM
czar's Avatar
Almost boosted
try changing the battery in the key fob ? ^_^
also why are u blocking half the radiator opening with your plate in your pic
Old Jul 21, 2009 | 02:45 AM
Thanks for your reply.
I have changed the battery believe it or not but I'm going to try a new keyfob instead and see if that makes a difference.
The reason my number plate is blocking the radiator is because it was either there, in the centre or at the other side...
Old Jul 21, 2009 | 09:30 AM
Check the switchs in the drivers door ( and passenger door)...if it thinks the door is open..the lock won't work. Door ajar light should be on though......
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
RXBae
Sep 14, 2015 03:54 AM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
stickmantijuana
Sep 4, 2015 10:31 PM
