Changing Belts need help
Old Jul 17, 2009 | 01:17 PM
PSTNLSS's Avatar
The Former PSNTLSS
I have felt various power loss and rough idles along with a slight tapping noise. Various members listened and Chrism told me its probably the belts
My question is what's the best way to replace the belts. I saw the DIY for the AP pulley install. But I am not sure if that works for this as well to replace the power steering and alternator belts
thanks
Old Jul 17, 2009 | 07:28 PM
04RX8man's Avatar
Rotary Powered Countryboy
I've noticed(never changed the belts) but taking the stock airbox out give you pretty easy access to the belts
Old Jul 17, 2009 | 09:08 PM
Jon316G's Avatar
Grasshopper
I changed my belts while installing the AP pulley.
Not hard at all.
These are from the service manual:
Changing Belts need help-drive-belt.jpg Changing Belts need help-ac-drive-belt.jpg
Old Jul 17, 2009 | 09:15 PM
PSTNLSS's Avatar
The Former PSNTLSS
Not hard at all.
Attachment 142403 Attachment 142404
thanks, thats what the AP install says so I wasnt sure if there was a way to remove belts without that
Old May 22, 2011 | 10:43 AM
Footman's Avatar
Dodging those Corollas
How does one know they need new belts? The belt "looks" fine to me. I'm at 86,000km.
Old May 22, 2011 | 10:49 AM
Footman's Avatar
In the service manual, it says to adjust tension the bolt C to a certain torque spec. Are they tightening it to the some tension on the belt itself, or so I just set the bolt C's torque and stop when it clicks?
Mazda seems to have some sort of belt tension test tool that applies force downwards onto the belt, I don't have a tool like that.
Old May 22, 2011 | 11:03 AM
kingaaron's Avatar
I change the belts when their are signs of cracks or they are tight and they still squeal. I don't have a tool to test the tension, but I just go by feel for how tight it is.
Old May 22, 2011 | 11:42 AM
EDZRIDE's Avatar
2005 White GT
The "torque spec" is for the A & B bolts.
The C bolt is what you turn to get the required deflection at the specified pressure. I don't have the tool either, just do it by feel.
LB2739
Jul 9, 2019 02:25 AM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
cgrichie
Sep 19, 2015 07:03 PM
Irvinb16
Sep 11, 2015 10:27 PM
