Hot Climate premix in car storage
Old Jul 13, 2009 | 03:09 PM
Spirograph's Avatar
AZ Hot Climate premix in car storage
I've just ordered a case of Idemitsu premix, but in the meantime I'm using MMO. Living in Phoenix, it's up around 115 degrees now, and last fill up I noticed that the MMO bottle was all expanded from heat - it hadn't split open yet but I wouldn't be surprised if it had. Anyone have advice on storage containers for premix that do well in Hades?
Old Jul 13, 2009 | 03:17 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Could you keep it in a dark cabinet or inside?
Have you considered Mazmart water pump and putting Redline Water Wetter in your car? I don't need the water pump since it's not that hot here in SF area and don't track. I did put Water Wetter in the coolant though.
Old Jul 13, 2009 | 03:24 PM
04RX8man's Avatar
Rotary Powered Countryboy
Well I dont quite get that hot here but high 90's and mine is ok.....do you keep it inthe storage compartment between the backseats(that's where I keep mine)
If you do I would just say don't fill it the whole way up so if it does expand it won't overflow but I believe it's more air expanding on the oil itself....
Old Jul 13, 2009 | 07:00 PM
BigMikeATL's Avatar
Watch out for the Wetter. There's a thread about problems it has caused with corrosion.
Old Jul 13, 2009 | 07:03 PM
Read the thread. Nobody really determined what it was. To say it's corrosion is just to spread unfounded rumours. Some people have issues, some people don't.
Old Jul 13, 2009 | 07:19 PM
invasion08's Avatar
I went to walmart and found a small water bottle that is made out of the same plastic as the big 5 gallon water jugs.
Old Jul 14, 2009 | 12:01 AM
Spirograph's Avatar
I don't want to keep it in the back storage compartment because I have the Nav DVD drive there, but maybe in the back seat cup holders compartment. I've looked at the MazMart water pump, but I think I'll wait for financial reasons. I've unbent the fins on one of my oil coolers, and I'll do the other one when I have time. I did put a 1/2 bottle of wetter in the coolant. I'll look for some of the containers that invasion08 recommends. I drive 500 miles a week, so I really need to keep the stuff in my car at all times, especially with how often the 8 needs refills.
MolecularConcept
Aug 5, 2015 04:43 PM
Obivious
Jul 29, 2015 05:57 PM
madrotor
Jul 26, 2015 12:06 PM
dbarber
Jul 25, 2015 01:34 PM
RX7.9
Jul 20, 2015 12:01 PM
