Unknown Plug
Old Jul 12, 2009 | 07:47 PM
TakezO's Avatar
Unknown Plug
I found a 12 pin connector in the rear console. Can anyone tell me what this is for?
Thanks.
Old Jul 12, 2009 | 07:50 PM
Spinning Sushi's Avatar
I <3 Sushi
I believe that is for navigation... though, I might be wrong.
Old Jul 12, 2009 | 07:53 PM
expo1's Avatar
He's as bad as Can
Did you but your car used? Maybe the last owner had an AMP or custom car PC in it?
Never mind, its related to the NAV system. The manual mentions a device that should be there for the map DVD's
File Type: pdf
Old Jul 13, 2009 | 08:05 AM
firebirdude's Avatar
User and Abuser
The NAV DVD system IS back there..... but I think it's normally UNDER the console? Maybe previous owner installed it themselves or made some modifications?
Old Jul 13, 2009 | 10:42 AM
myriadshalaks's Avatar
rot8ing
that appears to be what plugs into the dvd rom drive that boots the nav.
Old Jul 13, 2009 | 12:52 PM
Socket7's Avatar
ಠ_ಠ
Custom plug for sure. Don't know for what though. the OEM nav system sits where the plug comes through the plastics. If you had nav and it was removed, there would be a big gaping hole in the back of that cubby, rather then the single neat hole with a wiring harness attached.
Old Jul 13, 2009 | 07:45 PM
WikkedOne's Avatar
Deals on wheels
hhmm - power, groudn remote on the right.. and then 3 pairs of something.. doesn't even sound like that would be for a crossover or anything.. follow the wires and see where you end up
Old Jul 13, 2009 | 08:24 PM
TakezO's Avatar
Thanks for the pdf expo. Yes, I bought the car used. Ill try to follow the wires after work. You think I can use this as an AUX for another device?
Thanks for all the responses!
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
WranglerFan
Aug 21, 2022 01:29 PM
iphil
Sep 21, 2015 10:49 PM
Vedivan1
Sep 18, 2015 12:39 PM
Redheddude222
Sep 14, 2015 02:55 PM
