pulling out my hair already someone help...
Old Jul 8, 2009 | 11:31 PM
turbo_rx-8's Avatar
boostin_rx-8
ok here is my problem, i can take my car on a 100km drive, had have no problems with my power steering, then enxt time i pull off the driveway that stupid little steering wheel on the dash turns on and i have no power steering, its never the same, ive check the connector pins for corrosion, tension, and even ohm tested them, ive check powers and grounds, at the eps module and also at the rack, ive down a complete sweep of the steering whille checking the torque sensor to amke sure it doesnt cut out, every thing is testing good, any ideas??
Old Jul 9, 2009 | 08:03 AM
Ur PS motor is shot maybe ?
and sometimes if it overheats, it wont turn on.
Old Jul 9, 2009 | 09:39 AM
Nubo's Avatar
Lubricious
There's a good chance it is the electrical connector on the wiring sub-harness. When you start the car, the system checks resistance values for the PS inputs. If they are out of range, the PS is disabled. You may find that once the car warms up you can shut it down, restart and the power steering is enabled again. There is a replacement sub-harness that supercedes the original, to correct the problem. Or you can fix it yourself. Read the entire thread at:
https://www.rx8club.com/series-i-trouble-shooting-95/power-steering-failure-107481/
Old Jul 9, 2009 | 09:47 AM
Huey52's Avatar
Registered Zoom Zoomer
Yep, an example of the "graceful degradation" algorythm built into our PCM. The PS is a lower priority sub-system and as Nubo cites if the resistance value is too high it's deactivated to save power for higher priority systems.
Old Jul 9, 2009 | 01:07 PM
04RX8man's Avatar
Rotary Powered Countryboy
huh maybe something to do with the AWESOME drain tube for the coolant tank....
theblinkof
Oct 4, 2023 05:24 PM
200.mph
Dec 10, 2018 03:49 PM
duworm
Oct 1, 2015 04:57 PM
xAgyex
Sep 28, 2015 08:54 AM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
