radio blackout...help!
Old Jul 8, 2009 | 05:58 PM
chabinator's Avatar
I did the "Mazda RX-8 Custom iPod Installation" and I have now a radio black out?
even the display up the radio has no power..!!!???
any ideas?
fuses?
bad soldering?
Old Jul 9, 2009 | 12:40 AM
05rx8mazda's Avatar
B.I.G
what wires did you tap into?
did you plug everything back in properly? make sure than none of the wires came loose when you removed them. double check the big wiring harness. thats what poweres the radio.
Old Jul 10, 2009 | 01:47 AM
chabinator's Avatar
there is power going through the radio...because I hear the cd changer working when i plug the radio...but nothing is displayed on the radio...the ac don't work, same for music...
any ideas?
Old Jul 10, 2009 | 01:53 AM
Burton's Avatar
Rotary Rambler
fuses?
Old Jul 10, 2009 | 09:45 AM
AlbertaRX-8's Avatar
This seems to be the same issue as mine. It must be a fuse. I cant find az blown one tho. I didnt touch the radio at all, but did some wiring for my lambo doors install. I think I had a short... gonna work on it today, I will keep you informed if I find anything!
Mike
Old Jul 11, 2009 | 06:19 PM
chabinator's Avatar
I really have no idea what to do?
I will certainly not buy a new original week radio...
If i buy the metra kit and a new radio, will it fix the problem????
The fact that there is no power at all on the display up the radio is strange........
Old Jul 11, 2009 | 06:39 PM
shakeyourbrakes's Avatar
did you pull the radio out to install the adapter...a common problem, and one i came across, was the faceplate plug not being completely conntected with the actual radio housing. For example, if you pulled the radio out by pulling on the faceplate of the radio, the small plug about halfway up on both sides of the backside of the faceplate may not be fully connected. That will make the radio not function correctly, and the display either go out completely or have jarbled text. Push on the left side of the radio about halfway up (all around the faceplate too) and see if it fixes the problem, if it does then take the radio out and make sure the faceplate and housing are fully tightened together. I know this all is confusing, but I had the problem too awhile ago. And yea, the metra kit should fix the problem if its what i think it is. good luck
nadodave
Aug 28, 2019 05:55 AM
RX8mzda
Oct 1, 2015 10:17 PM
Learners_Permit
Sep 27, 2015 07:38 PM
CMRine04
Sep 23, 2015 09:31 AM
just1jack
Sep 9, 2015 04:45 PM
