FI Coils, HELP
Old Jun 28, 2009 | 04:11 PM
halimsteven's Avatar
FI Coils, HELP
hi there, i am here to find an advice from people who are willing to give me some.
i have 2004 RX8, and i have turbo (first greddy, and now is Mazsport).
i have Mazsport ignition solution, i have read some of the threads regarding all coils and mazsport, but i am running in different problems.
now, i just changed the sparkplugs, the new one, all of them, but it seems that it's misfiring on the higher RPM, especially when it's boosting. i have interceptor X.
i download the tuned Map again from my donggle, but it seems that it's having the same problems.
PLEASE LOOK AT THE PICTURES........
now the question is if you guys pay attention on the coil (the first one), it looks like it's gone. it's not the same as the rest. the top part is getting rusty, something like that. do you guys think this coil (the first one) is causing my car misfiring? is the first coil considered finished or done?.....
please help me out here before i decided to spend for a new set of coils..can anybody know what type of coils they use?
Attached Thumbnails FI Coils, HELP-img_0303.jpg   FI Coils, HELP-img_0460.jpg   FI Coils, HELP-img_0462.jpg   FI Coils, HELP-img_0464.jpg
Old Jun 28, 2009 | 04:17 PM
I8U's Avatar
I8U
There are many threads out right now about the Mazsport coils going bad. I say get rid of the setup and get your self a setup from BHR or Fluid.
Old Jun 28, 2009 | 04:35 PM
05rex8's Avatar
sold the 8... :(
the mazsport ignition uses Bosch coils
fluid has his own coils? can anybody give me the link about fluid coil set up?
i wanna see this...
what do you guys think about OKADA?
steven
Old Jun 28, 2009 | 04:37 PM
i was looking for it, but i didn't see exactly the same one as mazsport.
05rex8, can you give me the link if you know exact part? because i read before about the thread which was posted by mazdamaniac ....but i am looking for the right answer
steven
I8U's Avatar
I8U
OKADA is way over priced, just get your self a GM coil setup from any one of the vendors here that carry them. Get a hold of Ray at BHR, he'll hook you up.
Fluid is still working on theirs I believe. But honestly if you plan to change out just one coil you might as well change them all. Or you could take a multi meter to them and test them out. I believe anything more than 5 ohms of resistance is good sign it's time to start looking at replacing them.
Old Jun 28, 2009 | 04:43 PM
05rex8's Avatar
sold the 8... :(
I thought it was Bosch anyways....
http://www.microtechefi.com/microtec...?product_id=15
They look more like this though:
http://www.msdignition.com/Products/..._Ignition.aspx
Old Jun 28, 2009 | 04:49 PM
05rex8's Avatar
sold the 8... :(
Steven, I would PM Brice at Fluid Motorsports, he did the R&D for Scott when they were developing the coils. His car was the guinea pig apparently. He is still currently using the mazsport ignition setup in his car, so he should be able to point you in the right direction.
Old Jun 28, 2009 | 09:17 PM
yeah, he pmed me, but do you think my frist coil is burnt out from the way i looks? can you tell it?
steven
Old Jun 28, 2009 | 11:58 PM
chickenwafer's Avatar
Nope
I would be concerned about the masking tape holding your L2 plug wire together
Old Jun 29, 2009 | 12:39 AM
05rex8's Avatar
sold the 8... :(
steven
possibly, the only way to tell for sure is to test it
Old Jun 29, 2009 | 09:55 AM
chickenwafer, it was a tape to mark, not to patch the wire ...but, i am eager to find out if it is the first coil causing it.....it will be arriving by wednesday i hope
steven
Old Jun 29, 2009 | 11:11 AM
Nope
Oh ok, that's better.
I would still goto a GM Yukon LS2 coils setup- replacement coils are easier to find and cheaper and the system works with the proper dwell settings.
Old Jun 29, 2009 | 12:34 PM
that will be my next step. is it BHR set up? i heard that it doesn't work with turbo set up, but i still don't know, i jsut read at glance. you have BHR right, what do you think about it? do you need to change the dwell setting?
chickenwafer, do you know how to test the coil by using the multimeter?
steven
Old Jun 29, 2009 | 02:47 PM
blackenedwings's Avatar
Life begins @ 30 psi
steven
BHR ignition works great with FI, it just needs the dwell set to 5MS from ~2000 RPMs to redline. Stock dwell settings will work up to 300 g/s of flow, but they recommend setting the dwell regardless.
Old Jun 29, 2009 | 11:00 PM
outinnowhere3193's Avatar
outinnowhere3193
dwell to 5ms??? that's pretty high..but not high for the LS2 coils. I'm running those coils I just did my own set up and mine is set at 3ms and I boost normally 10 but when someone pulls me at a light I turn it up to 14 and I have no problems. But as far as the set up..you can buy your 4 coils local. and if ya get on ebay you can find the pig tails cheap. I think I have like 100 dollars in the coils and pig tails shipped to my door. But yeah I'd do the LS2 coils.
Old Jun 29, 2009 | 11:02 PM
outinnowhere3193
oh and as far as running..your car will run but run like **** with out the leading plug. But pull the wire and put it at a ground and take your spare plug and hook it up to a ground and watch your spark. If it's constant and never dies out then it should be good. But make sure if it misses only when hot...make sure it's hot before you do that...But you should see a solid steady spark and if you rev it...it should stay steady.
FubarI33t
Sep 28, 2015 08:45 PM
JAYDOH
Sep 24, 2015 01:54 PM
Sheldon24
Sep 21, 2015 04:53 PM
Vedivan1
Sep 18, 2015 12:39 PM
