Why does my 8 feel like it's going to die
Old Jun 27, 2009 | 06:07 PM
LURCH634's Avatar
Wher'e Going Streaking
When i am backing up my rpms go real low and it feels like it is going to die. It is an automatic by the way.
Old Jun 27, 2009 | 06:21 PM
Brettus's Avatar
Boosted Kiwi
be more specific ......
Old Jun 27, 2009 | 08:49 PM
LURCH634's Avatar
when i turn on the car and start to back up
Old Jun 27, 2009 | 08:53 PM
Z0oMzo0m's Avatar
does it stutter, is it a steady idle just lowering? we need more information on what your doing besides turning the car on and backing up...
miles?
the car warm or cold?
only in reverse?
Old Jun 28, 2009 | 01:38 PM
LURCH634's Avatar
-------------- ____________------------------------__________---------------
thats kinda of how it idels. stedy idle but than goes well under 1000 rpm's and bounces a little over 1000 and then under. if I let the car sit for a while it won't do it anymore
Old Jun 28, 2009 | 01:40 PM
Alexb's Avatar
desperately needs a drop
well. Sounds like it may need to warm up more? How soon after you turn it on are you backing up? 5 seconds? 10? 30?
Also, how much lower on the rpms? got a number? does it only happen when backing up? or just idle altogether?
Old Jun 28, 2009 | 06:24 PM
04RX8man's Avatar
Rotary Powered Countryboy
is ur e-brake off when backing? seen it before.....
if it's just at idle prob time to clean TB, MAF and possibly change coils/plugs if it's been awhile
Old Jun 28, 2009 | 06:39 PM
BigMikeATL's Avatar
When starting my 8 after sitting all night, it takes a few minutes for the idling to level off around 800. Prior to that it bounces between 800 and 1500 while warming up.
When reversing, I find that I do need to give the car more gas than normal.
Old Jun 28, 2009 | 06:50 PM
04RX8man's Avatar
the car runs at a higher rpm when it's cold because it dumps more fuel to help atomize more fuel so it willl start and also helps warm up the cat/o2 sensors quicker...
theblinkof
Oct 4, 2023 05:24 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
Danield97
Sep 30, 2015 05:59 PM
