CEL code for small Vacuum Leak
Old Jun 26, 2009 | 09:33 AM
Buckeye_rx8's Avatar
Small Vacuum Leak
I keep getting a CEL for "Small Vacuum Leak (less than .02 inches).
Anyone else get this?
It happens mainly on a restart (like if you're leaving a gas station) once the engine is warm and you get on it. I can't seem to replicate "the problem" with any consistancy, but the car drives fine otherwise. This is more an annoyance concern than an operating issue. But nevertheless, I would like to fix it.
Thoughts? Are there any vacuum lines that are prone to leaking?
I have a 04 6MT with 45K...Mods under the hood are Racing Beat intake scoop (and a stock air box). And yes, I capped the end of the VFAD once I deleted it.
Thanks in advance for your comments
Old Jun 30, 2009 | 11:12 AM
Nobody has any ideas on where to start looking?
LOL that nobody has an opinion...that has got to be an internet first.
Okay, I was hoping for a shortcut, but I guess I will just have to use trial and error...
Old Jun 30, 2009 | 11:29 AM
bad gas cap?
Old Jun 30, 2009 | 11:34 AM
bose's Avatar
Reginald P. Billingsly
mine did the same a few times, most likely like Jedi mentioned. I replace the gas cap and it hasn't come back.
Old Jun 30, 2009 | 11:46 AM
ken-x8's Avatar
What number is the code? If it's P0455, search that and you'll find a bunch of posts. Usually the gas cap, but sometimes a more expensive component and one poor soul who accidentally drilled into something while installing speakers.
The vacuum leak codes usually come on as soon as you start the car, after it's sat for a while. The car monitors vacuum while it's sitting, and sets the code if it leaked down too far. If it comes on while you're driving, that's not the expected pattern.
Ken
Old Jun 30, 2009 | 12:55 PM
Thanks guys...I will write down the code (and do a search for it) the next time I get it. I've just been clearing it up til now.
I will replace the gas cap as a first step and see if that clears things up.
Thanks again for the advice.
Old Jul 1, 2009 | 12:31 AM
Soa[y water is your friend.
If you have an after market intake check the cap under the TB throttle body.
Old Jul 20, 2009 | 03:39 PM
3 weeks and no CEL...
Verdict = bad gas cap.
Thanks everyone
WranglerFan
Aug 21, 2022 01:29 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
Irvinb16
Sep 11, 2015 10:27 PM
iwannarun
Sep 6, 2015 01:37 PM
