Low end?
Old Jun 21, 2009 | 04:16 PM
636's Avatar
636
Rice Police
Turbo
Old Jun 21, 2009 | 04:31 PM
rx8thunder's Avatar
Being (new) single rocks!
or if you want to avoid FI, change diff to 4.777
Old Jun 21, 2009 | 04:33 PM
Spinning Sushi's Avatar
I <3 Sushi
The electric supercharger that are sold on e-bay should help your low end.
Old Jun 21, 2009 | 05:06 PM
05rex8's Avatar
sold the 8... :(
best mod would be to sell the car and buy a mustang
Old Jun 21, 2009 | 07:17 PM
Mawnee's Avatar
I divide by zero
LS1 swap ?
Old Jun 22, 2009 | 04:06 PM
04RX8man's Avatar
Rotary Powered Countryboy
turbo, s/c ...or 4.777 diff would b the cheapest..(i think)
Old Jun 22, 2009 | 04:21 PM
ChrisRX8PR's Avatar
13B-RE
Low end? What low end?....
I don't know what that is....I didn't buy a V8, I bought a rotary.
Chris
Old Jun 22, 2009 | 05:42 PM
bse50's Avatar
#50
IMO, you can pick up a certain percentage of torque to the rear wheels at all RPM points with the 4.44-4.77 swap but the torque curve offered by an F/I kit will be "better" (although WAY more expensive). Both F/I and 4.77 options would be pretty cool, though.
The FI will be more expensive, for sure, but your highway mpg won't suffer that much if well tuned and balanced for road use.
The 4.77 drive is also intended for twisty roads\track\autoX use, the needs of a car used on a track are different than the needs of a "tuned" road going car.
I would say turbo and i have a shorter final gear
Especially if you like straight, off the line pulls the turbo will be the best choice. The final gear really only shows up during a twisty circuit!
Old Jun 22, 2009 | 05:50 PM
+1 for the eBay superturbo... I have a nice strong pull at the low rpm's
Old Jun 22, 2009 | 05:53 PM
bse50's Avatar
#50
A 4.77 swap willl provide a 7% increase in torque across the entire RPM range but F/I does a lot more in a slightly smaller RPM range. The cost differences are where the nuances lie.
Yep but the use for the final gear is still different. Shortening gears is not always a good solution
Old Jun 22, 2009 | 05:57 PM
bse50's Avatar
#50
Whatever
Old Jun 22, 2009 | 06:35 PM
another vote for nuances; 4-rotor ...
Old Jun 22, 2009 | 10:32 PM
SPHINX144's Avatar
am I detecting sarcasm in that statement?
no, seriously I've never heard anyone say those electric turbochargers even work.
Old Jun 22, 2009 | 10:34 PM
dondo's Avatar
100% baller (finally!)
^ a group buy just started in another thread
Old Jun 22, 2009 | 10:46 PM
SPHINX144's Avatar
will look into it.
Old Jun 23, 2009 | 01:12 AM
shazy's Avatar
Give the guy a break... Only way is turbo, or Go S/C, which will keep nearly the same power curve as stock. Only difference, there's more power involved
RevMeHarder
Jun 1, 2026 02:30 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
TJSiegrist
Sep 10, 2015 09:29 AM
