reverse grind?
Old Jun 20, 2009 | 10:20 PM
CaptainEggs's Avatar
Question reverse grind?
anyone grind when you go into reverse from time to time? (M/T) cause i was backing out and it seems like its in then i start to let the clutch go and GRIND!
Old Jun 20, 2009 | 10:23 PM
andrew186's Avatar
Seeking Energon for my 8
yeah it happens to me sometimes, to avoid it keep the backward pressure on the gknob while selecting reverse and lift the clutch very slowly
Old Jun 20, 2009 | 11:02 PM
trustbuddy's Avatar
it used to happen to me.
i got a new transmission from mazda as i was still under bumper to bumper warranty.
Old Jun 20, 2009 | 11:32 PM
crittyex8's Avatar
black8
the tranny is under a 60k mile warranty i believe.
Old Jun 21, 2009 | 12:06 AM
Rhawb's Avatar
Has the whole shit.
I've noticed that occasionally 1st and reverse don't engage fully - this seems to happen on most/all cars, best I can tell. It has happened on most of mine, at least. If you're experienced enough with the car you can usually just feel that the shift lever hasn't quite moved all the way into its gate. The problem can be fixed by going to neutral, re-clutching, and trying again.
Alternatively, could it be that you're still rolling forward before reversing? I know that's a pretty common culprit too.
If you know your problem fits neither of those issues, you may want to have someone take a look at the car just as a preventative measure. It's certainly not a common problem, so if it becomes frequent get it fixed asap.
Old Jun 21, 2009 | 04:14 AM
always.anthony's Avatar
is looking for his torque
usually not in all the way, you can only hop in reverse when "not moving" as in your tires are not moving, and if are at like 1mph max. if you try to go in while moving, you just grind.
Old Jun 21, 2009 | 09:35 AM
04RX8man's Avatar
Rotary Powered Countryboy
I figures out if you take it in an out of reverse like twice it goes in and have not had it grind since i started doing that
Old Jun 21, 2009 | 09:40 AM
Burton's Avatar
Rotary Rambler
Mine does the exact same thing... Just pay attention when you are putting it in reverse and if it does not 'click' in then put it in N let the clutch out and re do it. Mazda has a thing in the manual that says "If you experience difficulty in putting the car in reverse put it in neutral and retry it"
Old Jun 21, 2009 | 10:11 AM
04RX8man's Avatar
^yeah those high tech engineers are good...."if it doesn't work try it again" haha
Old Jun 21, 2009 | 10:14 AM
Marklar's Avatar
They stole that technique from software engineers.
Old Jun 21, 2009 | 12:04 PM
OK thanks for all the info.=) that grind hasn't happened to me in a while but, yesterday was a bad day.. for the first time EVER i started to burn the clutch when going up my driveway. i was giving too much gas and not a lot of clutch. i noticed what i was doing so i stopped right away. T_T
Old Jun 22, 2009 | 12:49 PM
CyberPitz's Avatar
Huge hole is huge
Reverse has no syncros, so there will be good chances you're going to grind. It happens to the best of us.
Old Jun 22, 2009 | 01:46 PM
04RX8man's Avatar
^are you calling me the best??? lol J/K
Old Jun 22, 2009 | 10:43 PM
SPHINX144's Avatar
haha... indeed. but it actually works.
It's a common event that characterizes all manual transmissions from time to time.
Old Jun 22, 2009 | 11:13 PM
luv4eternity's Avatar
Low is a lifestyle
probably stole the technique from Ferrari :D
Old Jun 22, 2009 | 11:21 PM
Grungepup's Avatar
Oilfield trash
quick fix.... dont put it in reverse... you lose all the torque
but seriously, if when putting it into gear and it doesn't "grab" apply slight pressure to the shifter while releasing the clutch and giving it a little gas, the gear will slide right in no problem
Old Jun 24, 2009 | 07:31 PM
RedLine9x's Avatar
it happens, no biggie, try again :P
Old Jun 25, 2009 | 04:48 PM
The Drunk IT Guy's Avatar
I just shat myself
90% of the time it goes into reverse just fine. I think I've developed muscle memory that helps me do it just right. But if it doesn't then I put it into first then back to reverse and it typically goes in. I haven't had a chance to try the "give it a little gas" technique.
theblinkof
Oct 4, 2023 05:24 PM
mitchrx8
Sep 13, 2015 08:05 AM
airlive
Sep 7, 2015 08:32 PM
superROB23
Sep 4, 2015 01:22 AM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
